20 Most Recent
Amana ACF422 Electric Kitchen Range Questions & Answers
I have the code F9 what can I do
F9 usually means that the oven lock is partially engaged after cleaning. Normally, the door unlocks automatically after the cleaning cycle is through. Unplug or turn the oven off a the breaker switch. Leave it off for a moment. When you turn it back on, the error should resolve. As a caution, unlock problems are notorious after cleaning, a long with fried electronic controls. Clean sparingly. Thanks for using fixya.
We recently moved, when we got to our new house we
i would first try the breaker it sounds like you only have half the power coming to unit and the light and clock will work but the heating componets will not as they require the full 220-245 volts
it sounds very odd that everything as far as burners and elements are out but you have a clock display and light... you have lost one of the legs of power somehow...either the double breaker is not fully on and may require turning off oven breaker and resetting or half the breaker has failed... a sure way of testing would be to pull out and with a volt meter test to see that you have 220-245 volts coming to oven,,, hope this helps out repost if anymore questions...
