20 Most Recent
Amana ACF3355 Gas Kitchen Range Questions & Answers
Whatdoes an oven igniter do as opposed to the oven bake igniter?
Initors work with oven safety valves and open gas safety valves when the amp draw changes as the ignitor heats up. Ig niters light the flame and then become a thermocouple and send back confirmation of ignition to the central control. The model above uses a glow bar ignitor which is wired in series with the oven control and safety valve. The most common mistake when diagnosing the ignitor is working is you see it glowing. But that does not mean it is strong enough to open the bi-metal inside the gas safety valve which requires a minimum of 3.5 amps to bend the bi-metal so it will release gas to the burner. -PawPaw. If you need further help, reach me via phone at
https://www.6ya.com/expert/dan_73bbd84fe1d95b61
We recently moved, when we got to our new house we
i would first try the breaker it sounds like you only have half the power coming to unit and the light and clock will work but the heating componets will not as they require the full 220-245 volts
it sounds very odd that everything as far as burners and elements are out but you have a clock display and light... you have lost one of the legs of power somehow...either the double breaker is not fully on and may require turning off oven breaker and resetting or half the breaker has failed... a sure way of testing would be to pull out and with a volt meter test to see that you have 220-245 volts coming to oven,,, hope this helps out repost if anymore questions...
