20 Most Recent
Black & Decker 9072CTN Cordless Screwdriver Questions & Answers
I need to buy battery
Either you can buy the original battery from Black and Decker or you can replace with the same mA rating with the regular types available in all stores any rechargebale variety with a good mA rating.
Couple in series and parallel to get the desired voltage and current rating.
I have a B&D 9019
Hi Boyd,
Welcome to fixya!
I located a parts breakdown for you. Since the clutch worked before you took it apart, I think if you just take it down to the clutch and redo it, you should be good to go.
Here is the website for the parts diagram: http://www.toolpartsdirect.com/cgi-bin/modelsearch.cgi?brand=blackdecker&model=9019
Copy and paste the entire address into your web browser and a list of different 9019 screwdrivers will come up. Click on the one that matches yours and you will see your parts diagram. You can click on the link on the diagram and it will open in zoom on a new page.
Good luck to you.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
I need to buy battery for KC 9072. From where I
you can buy it direct from Dewalt or if you give me your general area I will try and find one more locally. The part number I found is 497755-01 and it lists for around 11.00 Please let me know if I can help more and if you have any more question please ask before voting. The site is "dewaltservicenet.com" and I used the model number 9072ctn to find it.
I can't seem to get the end piece to loosen or
I don't think the end comes off this model. I think just below the switch you will find a sliding compartment for storage of bits. pull back on it with your thumb and it should slide open. Let me know if this works.
Drill bit won't in securely - Black & Decker DP240 Screwdriver
I am going to assume that the bit you are trying to insert is a 1/4 hex drive. If so are you pulling or pushing on the collar of the tool holder to insert or remove a bit. Make sure that the hex on the bit is not twisted also. Let me know and I will go from there.
My cordless Black & Decker
Most likely it is the switch has gone bad or just a loose connection on the switch . you can take it apart and check the switch connections and make sure they all have a good connection.If they do then you should take a volt meter and make sure that when you puch the button they get proper voltage if not then order a switch and replace it .
Pivot plus Drill
see www.dewaltservicenet.com . look for the icon find it now & enter the model #
How to open a B&D
push the 2 pin out & careful when u seperate.gear's are made of plastic
Remove the pins on a
use a end of a small nail to tap it on thru'. replacement is just the reverse [don't need new pins if you are careful!]
Where can I get a battery for Black & Decker Drill CD 1000?
This will be a suggestion...but for mine I bought two 18650 LiFePo4 cells (3.7V each) and replaced the original NiCd Batteries. It has been working for many years now, since the original batteries expired and stop working in 2002 (I bought the CD 1000 back in 1994!!!!!). You have to use a special charger for the new ones but they stay charged a lot more and the drill has more torque.
