20 Most Recent Universal Battery Charger Charges Multiple Combination Questions & Answers
0answers
2answers
How long does it take to charge batteries?
depending on the type of battery and charger the time usually takes from 6 to 12 hrs. for a full charge. Shorter charging time will result in battery not operating to its full potential
1/14/2013 3:50:31 AM • Universal... • Answered on Jan 14, 2013
Rechargable Batteries Battery Charger
When batteries are placed into the charge mode, the red light will come on.
When fully charged, on those units with a green light, the green light will be an indication that your batteries are charged and if your unit has no green light, the fully charged indication will be when the red light turns iff.
1/22/2011 5:15:52 PM • Universal... • Answered on Jan 22, 2011
Sears battery charger power issue
Hello. No simple solution. And unfortunately the cost of repair is more than a replacement. Joe
3/23/2010 12:23:17 AM • Universal... • Answered on Mar 23, 2010
Charger
next to the jack on the camcorder it should have a diagram that shows polarity (a + and - sign) for the plug, the tip should be one sign and barrel or outside of the plug should show the other polarity. you have to have your plug with the correct polarity, and you have to have the correct voltage( it should say 9v or 12v or something like that) and the supply you use should be as high or higher of a current rateing as recommended in your users manual or printed on the supple that came with it.
1/10/2009 4:27:20 AM • Universal... • Answered on Jan 10, 2009
0answers
Charger needed
Be the first to answer 8/11/2008 1:43:09 PM • Universal... • Posted on Aug 11, 2008Be the first to answer
tip
Checking an AC-DC Power Transformer as the cause of a device failure
After a couple of personal experiences, I found that many electronic devices that use a wall plug in AC to DC power transformer ( commonly known as a power brick) are the most common cause of failure to the electronic device they are connected up to. NEVER just check this for voltage. A power brick can easily show you it's supplying the right voltage BUT lacks the Amperage that your device requires. It's usually the amperage that fails. THIS IS THE RIGHT WAY TO CHECK A POWER BRICK: Invest in a purchase of a multi voltage universal power brick from an electronics store or Amazon. Buy one that has voltage adjustments from 3 - 5 - 7.5 - 9 - 12 DC volts MOST IMPORTANT that this new brick be rated for 2.5 or 3.0 AMPS ( also known as 2500 - 3000 MaH). It should also be the type which comes with a variety of tips to plug into different devices. ....Before you declare that your electronic device is no good...... Replace the power brick with the new one you invested in. Adjust the voltage to the same voltage as what was supplied on the original power brick. Install the right tip to properly plug into your device AND MAKE SURE THAT IT IS PROPERLY POLARIZED. On the orig. brick or on your device it shows the proper position of + and - voltage for proper connection. Usually the center is + but check first. Don't worry about amperage. A 3 amp brick covers just about every need for different devices and your device will only use what it needs. It will NOT over power your device. But again make sure the voltage is properly set. Now with the brick plugged into the wall and plugged into your device, power up your device and see if it now works. If it doesn't, it's the device. if it does, it's your original brick going out. What I do is buy a dedicated power brick to replace my test brick so I can use it again for the next time I need to check something. You'll be surprised at how many times you can salvage your electronic device by using this simple test method.
on May 15, 2019 • Electronics - Others
The electric water heater is not heating any water
Check to see if your GFI has tripped. That heater should be on one. Or your breaker for the tank.
2/3/2011 8:09:00 PM • Universal... • Answered on Feb 03, 2011
I have a Keb 12F5 that shows E.EF external fault. How to solve it please?
It appears to be something to do with this https://www.google.com/search?q=keb+12f5+that+shows+E.EF+external+fault 7.13.1.6 External fault With Pn.04 "Ext. fault input selection", one or more digital inputs can be programmed which can trigger the error "31: ERROR! External input" (E.EF). With Pn.03 "E.EF stopping mode" , the response of the inverter to the digital input is defined. With Pn.65/ bit 1 "2: Pn.04 = E.UP https://www.keb.su/doc/Instrukciya%20F5-A_E_H%20ver.4.0%20(ang.).pdf ..
2/27/2024 6:55:25 AM • Electronics -... • Answered on Feb 27, 2024
How do I connect my laptop to the TV?
Back in 2014 it wasn't so easy. Laptop with an HDMI port and a smart television with HDMI. ..
2/27/2024 6:47:57 AM • Electronics -... • Answered on Feb 27, 2024
2answers
I have an Emerson Quiet Kool Rooftop R/V air
I have a quiet cool roof top air conditioner and am looking for parts for it.
2/9/2024 5:25:36 AM • Electronics -... • Answered on Feb 09, 2024
Istar x 20000 USER MANUAL
Help in the link, but the one good site doesn't like my Ad Blocker! https://www.google.com/search?q=Istar+x+20000+USER+MANUAL ..
12/23/2023 11:37:12 PM • Electronics -... • Answered on Dec 23, 2023
Problem with oelmaier pac2 inverter
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjckMaPzKODAxUVj4kEHR5mBFMQFnoECBQQAQ&url=https%3A%2F%2Fforums.whirlpool.net.au%2Farchive%2F1447917&usg=AOvVaw1FGjdFQoufkwdXZJgXWdGz&opi=89978449
12/22/2023 5:44:02 PM • Electronics -... • Answered on Dec 22, 2023
Universal Battery Charger Charges Multiple Combination Logo
16 questions posted
Top Universal Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you an Universal Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Universal Electronics - Others
Most Popular Question
rechargable batteries battery charger
