20 Most Recent Samsung SHR-2082 8 Channel Stand Alone Dvr with Cdrw Questions & Answers
Samsung SDR-B74301 All in One Security System. I lost a video feed on cameras and cant get any visual. The plugs are all plugged in.
Question edited for a lot more clarity. Question moved to Samsung Home Security. Swap the camera with no feed for one that does. If that location works, you know the camera is faulty. If the known working camera doesn't work, you know it is the wiring of the power supply to that location.
Samsung SDR-B74301 Quick Start Manual
ManualsLib https://www.manualslib.com > ... > SDR-B74301 View and Download Samsung SDR-B74301 quick start manual online. SAMSUNG ALL-IN-ONE SECURITY SYSTEM. SDR-B74301 security system pdf manual. ..
7/15/2023 3:20:52 PM • Samsung SHR-2082... • Answered on Jul 15, 2023
4answers
Menu pasword
The manual says:
You cannot enter MENU by forgotten password.
- If you forget the password, you shall reset SHR-2160/2162/2080/2082 DVR to
the values set at the factory. Keep pressing both the "MODE" button and the
"PTZ" button on the left for 5 seconds, Keep pressing both the "MODE" button
and the "PTZ" button on the left for 5 seconds. The password default is "4321".
6/8/2016 12:30:18 PM • Samsung SHR-2082... • Answered on Jun 08, 2016
Forget password for samsung security model sde
How do I reset my password with out my remote
2/28/2016 9:19:09 AM • Samsung SHR-2082... • Answered on Feb 28, 2016
Samsung shr-1040
Best to get a USB thumb drive and download the video needed to the thumb or flash drive. Put it on the computer and there you can use a program like Snagit to capture the best parts and save it for police. Saves a lot of wasted time
8/17/2014 6:00:08 AM • Samsung SHR-2082... • Answered on Aug 17, 2014
Hi Ive Samsung camera system, model is: SDR-5100N
4321
8/7/2014 6:29:14 AM • Samsung SHR-2082... • Answered on Aug 07, 2014
How to reprogram a samsung digital video recorders battery
www.samsung.com/us/support/downloads
6/29/2014 7:25:54 PM • Samsung SHR-2082... • Answered on Jun 29, 2014
Dvr password reset
see hte following link below. you need to set the DVR back to default in order to reset the password. http://www.safe-n-secureinc.com/Support/Samsung/Samsung%20SHR-2160-2162-2080-2082-ENG.pdf
11/7/2013 6:29:11 AM • Samsung SHR-2082... • Answered on Nov 07, 2013
3answers
Samsung shr 1040 4 channel dvr
Try this it will work:
Press and hold "ch1 and mode" buttons at the same time and hold for about 45 sec. This will change yoursetting to VGA . You can fined this info in your user manual on page # 6-13 see note at bottom of page for "HIDDEN KEY" shortcut's
It's a good system dont give up.
10/27/2012 8:16:59 PM • Samsung SHR-2082... • Answered on Oct 27, 2012
Admin pass word
HI
the admin password is 4321
If this does not work, you can reset the device.to the values set at the factory. Keep pressing both the "MODE" button and the
"PTZ" button on the left for 5 seconds until LED lights on in the order of
1➝2➝3➝4➝5
Then you can use the default admin password and take it from there.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
9/9/2011 2:06:31 AM • Samsung SHR-2082... • Answered on Sep 09, 2011
Need the manual to try
here's the online manual in a vertical format...
http://www.scribd.com/doc/56426559/SHR-208X-216X-ENG
Bill
8/18/2011 12:12:42 AM • Samsung SHR-2082... • Answered on Aug 18, 2011
Is this dvr capable of
The SHR-2082 cannot record OTA TV because it does not have a tuner. It is meant to record video from a set of security cameras.
The manual for the SHR-2082 is available from Samsung support here: http://www.samsung.com/us/support/downloads/SHR-2082 .
I wish that I had better news for you.
6/17/2011 2:29:06 AM • Samsung SHR-2082... • Answered on Jun 17, 2011
I have recorded footage from 9channel samsung DVR
Normally the recordings are in MP4 format and a lot of players cannot play it. You would need divx plus player. Its free.
Cheers
TeaCii
4/23/2010 9:38:26 AM • Samsung SHR-2082... • Answered on Apr 23, 2010
Samsung dvr shr 2082
go to samsung-security.com and type in shr-2082 to get to archived discontinued literature.
2/4/2010 10:34:07 PM • Samsung SHR-2082... • Answered on Feb 04, 2010
Samsung SHR-1040 Digital Video Recorder
it sound like the system is locked up or your hard drive is going bad. write down all the info on the unit and reset and reprogram the unit. this may solve your problem if not you my need to send it in for repair.
•Factory Reset Hidden Key :
Mode Key + CH 2
•The Password and all setting
value will return to the initial
default value.
•Default Password is ‘4321’ .
mj
9/7/2009 1:10:35 AM • Samsung SHR-2082... • Answered on Sep 07, 2009
SHR-2082 RECORDING TIME ZONE FROZEN!
David,
try setting the time to something different (Like a day and hour from the current setting) than the current time and see if that come up if so then set the system to the current time and date and check again, if that solves your problem great if not reset your system and reprogram it.
Mode Key + CH 2
default value.
mj
9/7/2009 1:05:51 AM • Samsung SHR-2082... • Answered on Sep 07, 2009
Samsung SHR-1040 Won't Initialize
try to reset the unit and start over.
Mode Key + CH 2
default value.
mj
9/7/2009 12:54:39 AM • Samsung SHR-2082... • Answered on Sep 07, 2009
Samsung shr-1040 playback is blocky
Sorry, but there is no way to turn off the compression. That is the just the way a quad works. It compresses the 4 video signals to 1 channel. The only way to get around it is to buy a 4 channel unit. 1 channel per camera.
Rob
8/5/2009 2:36:11 AM • Samsung SHR-2082... • Answered on Aug 05, 2009
Product has bugs in it--buyer be ware--it's junk.
I understand Frys sells reconditioned items without letting the purchaser know. Could be your situation. Have you tried contacting Samsung?
7/25/2009 6:14:03 PM • Samsung SHR-2082... • Answered on Jul 25, 2009
I have a samsung 2082 every thank comes on but
First try,
Problem: All the front LEDs are in operation but the monitor remains black.
Solution: Video out may come out differently with the connected monitor. In short, Video
Out is set to Composite Output but connected to VGA Input Monitor or vice
versa. If the MODE and ZOOM buttons are pressed and hold for 5 seconds, the
system restarts while alarming beep sound.
Second and works 99.9% of the time but you have to reset all parameters
Factory Default will be done as follows;
- In Live mode, press and hold down MODE and then PTZ on the front panel for
6 seconds to reset all settings to factory.
Default menu password 4321
7/3/2009 7:54:51 PM • Samsung SHR-2082... • Answered on Jul 03, 2009
2answers
I have a samsung home
The manual says:
You can download the user manual here:
http://samsungsecurity.com/product/p_detail.asp?seq=94&sel_seq=64
6/16/2009 2:35:07 PM • Samsung SHR-2082... • Answered on Jun 16, 2009
Samsung SHR-2082 8 Channel Stand Alone Dvr with Cdrw Logo
80 questions posted
Top Samsung Home Security Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Eric
ADMIN Eric
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Home Security
Most Popular Question
admin pass word
  • Home Security
