20 Most Recent
Lorex SG6153 / Weather Resistant Mini Color Camera with Night Vision Questions & Answers
RL-01CTV
POWER
RED IS THE +POWER
BLACK IS COMMON
SIGNAL
YELLOW IS + VIDEO
GREEN OR WHITE IS -VIDEO
Whats colors are what for my weatherproof security camera it has four wires
Red & Black is the power wires (Red +) & (Black -). The other two wires are probably the video signal (normally green & white). If you have a separate coaxial connection for the video signal, the other two wires could be for zoom lens control.Look up the make & model on line and check out the specs. Hope it helps. Ed
Rewire lorex SG6153P camera
I HAVE A SECURITY CAMERA GOT WITH THE WIRES RIPD FROM BACK OF IT 4 WITH WIRES 1 RED 1 WHITE 1 YELLOW AND 1 THICK BLACK WIRE HOW CAN I REWIRE IT?????
RIPD CAMERA WIRES!!!
you need power to the red and black, white to a rc plug center pin yellow to the center pin of a rc plug and there should be a bare wire you need to split it off to the outside section of the yellow and white rc plug
I need to wire it to a tv but have only camera no
Okay - from a google search placing the information
Lorex SG6153 into the text box came up with the web site below.
http://www.google.com/products/catalog?hl=en&q=Lorex+SG6153&um=1&ie=UTF-8&cid=3330978625885084760&ei=zLwIS5CQDZCINKyPlLoK&sa=X&oi=product_catalog_result&ct=result&resnum=4&ved=0CBkQ8wIwAw&os=tech-specs
Here it gave me the specs that you have:
RCA jack output for your Video output connection
RCA Jack for both Left and Right Audio outputs.
So you will need to have Auxillary video and audio inputs on your TV. Most Tv''s have RCA Video and Audio inputs - many so you can connect your VHS player into the TV.
So - If you go to a local Target, Wallmart or even better yet Radio Shack or Best Buy. You will be able to obtain/purchase RCA male connector to RCA male connector cables. Many of these places have them in all kinds of lenths 'most common is 6feet'.
Many of them have all three connector's/cables together.
Yellow end is for the video
Red end is for the Right Audio
White end is for the Left audio.
Hope this all makes sense?
Blessings,
A/V Media Guy
Can my Lorax mc2700 be viewed from my phone
The Lorax MC2700 is a portable radio that does not have Wi-Fi or Bluetooth connectivity. As a result, it cannot be viewed or controlled from a phone or other device. It can only be controlled using its physical controls
