20 Most Recent Electric Door Light Switch Questions & Answers
Check the small "button" that gets depressed when the door closes. Perhaps it's stuck IN, which is the OFF position. If it doesn't "pop out" when the door opens, then it won't turn on. Tug on it if it's stuck, you can use pliers and work it in and out a few times, then hit it with WD 40 or similar lube to help it free up.
There's only one wire to the back of this switch, so if you have to replace it, it's really easy, It unscrews from the door frame. Just a heads-up though, if that wire falls off, it can be a pain to fish back out of the body to reconnect!
Electric Door... | Answered on Feb 08, 2011
The problem is that you need to understand that the red and black wires may not be power and return. The main red line is broken at a point and a new cable run to the light ( red + black) or (blue+ brown) this is merely the switch circuit fore that light. So if you mistake the two points it may be that what you have is red+red to your globe. ( Is that clear?) you would need to find the common black + the red to take power to the Red+black to your new ceiling rose, but breaking the now new red wire somewhere and joining in a new red_+ black that goes down to the switch
Use a power checking device as sometimes in some roses where multiple circuitsw feed fom Black and Black can be live
Please rate my help++++Thanks for using FIXYA
Electric Door... | Answered on May 29, 2010
used a multi tester to locate the right terminals
Electric Door... | Answered on Jan 02, 2010
this cannot be easily answered, if the power supply is in the fixture simply run a new wire to the new switch. if the power is in the switch run a wire from the same switchbox to the new location and wirenut the wires on the switch to your new wire. remove the switch to the new location and ummy off your old switchbox.in either case the latter should be the easiest and safest way to go. always be sure to turn the power off at the panel box. and remember electrical work isnt like your typical trades bad things can happen when very quickly if you dont know what you are doing.
common megane fault im afraid the water gets down by rubber and lands directly onto motor. great french design. new one im afraid and try to place something over motor bit of plastic to let water drip away. parts handy got on line. look up megane window motor and see results on google. about 65 sterling. regards mike autosolutions.ie
Electric Door... | Answered on Mar 26, 2009
You Need to Test with a electric tester and Identify a Hot and a nuetral in t the Box. If you find them that is what you need AT LT.If you are missing either you will have to add it. 3W switches can be installed numerous ways.If you have More info let me know.
Master Electrician
Electric Door... | Answered on Jan 04, 2009
Put one wire from switch to black wiring coming in and the other to the black going to the ballast.
If you do not understand please post back
Connecting 12 batteries in series would give slightly more than 61 volts. Considering that under load voltage will drop then it should be ok. Breaker goes between battery and motor on positive wire.
Electric... | Answered on Oct 14, 2019
Hi!
We help people repair their Clarke Generators. You can find testing procedures here: https://www.generatorguru.com/contact-us/
We also hold all the parts possible for all the Clarke Generators and have a "Parts Search Service" if the part is not listed on our site. Check us out on our site.
Parts Spares for Generators and Small Engine Machinery
Electric... | Answered on Sep 13, 2019
either short or failure of gfci
Electric... | Answered on Jun 08, 2019
Tip
Repair broken power cord
I have a 50-ft power cord for my electric pole saw. In an accident, the saw cut the power cord. It's long cable and I want to save it. My method keeps the cable lean and retain it's strength. It's not water-proof, but I never use a pole saw in a rainy day.
on May 31, 2019 | Electrical Supplies
If you make your point of reference the flywheel (starter side) of the motor then rotation is clockwise. If your point of reference is the alternator or the end opposite the motor flywheel, then it will be CCW.
Electric... | Answered on Apr 26, 2019
Electric Door Light Switch Logo
16 questions posted
Top Electrical Supplies Experts
Fahr Quad
NOEL
NOEL
vince
Are you an Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
Electric Electrical Supplies
  • Electric Electrical Supplies
Most Popular Question
renault megane 1998
  • Electrical Supplies
