20 Most Recent
Xerox DC440ST Copier Questions & Answers
Xerox dc 440 dadf 8.5"/14.0" scaning problam
Try cleaning the scanning feeder first and to make sure that there is nothing stuck over the scanning lense alternatly you can try by downloading and updating the updated driver from manufacturer`s website.
DC440st
This problem can be a bad main motor. The motor has gears on it and they can bind when they are worn. The motor assembly itself electrically can be bad.
If there is something binding in the gear train assembly this can cause the motor not to turn. A bound up copy cartridge can cause the motor not to turn.
A bad board can also cause this not to start.
To replace the main motor, it is very detailed and time consuming.
Try a service call, hope it is cheap enough and the copier is in good shape besides the motor being bad.
How to fix error replace/print
You will be wasting money buying just a chip. The toner and all is in the cartridge. Normally when the replace message comes on, the cartridge is shot.
How to connect the machine
Be sure that you have network option installed. On top cover of the printer itself (under the scanner) you can see a floppy drive, can you? OK, then it is capable of network printing. Also parallel (Mini-Centronics) port will work.
You may try parallel printing first, it is easier. Download from
www.xerox.com/support drivers for your DC440ST.
Install driver. Connect parallel port to computer via Cenntronics cable and you'll be ready.
If you want to print from network you must have UNIX printing installed in Windows. You have to create a new port in the printer driver and create a print queue and name it "lp". Port address is also needed. For example 192.168.0.1.
To set up network address on the printer you have to log into the printer as administrator.
Press (key) button on the top right part of the keyboard.
On the touch screen enter: #22222 (hash sign and five 5's)
Enter "Networks settings" "TCP/IP" "network address" "STATIC" "192.168.0.!" for example" "SAVE" "QUIT" and the printer will boot.
You may have to ping for the network address to see if it responds. If the copier/printer prints out a config sheet in five minutes you can check the address and other setting you just did.
If the printer DOES NOT PRINT the config sheet it may be disabled in settings. You can log in again (key) #22222 and enable "print config sheet" + reboot again.
Sir when we take copy it rotate auto mat by 180
On this machine either the paper is loaded wrong, or the settings in the machine menu are set to landscape or portrit. This is either in the machine or from the computer one is printing from. If it is from the computer check the printer settings. On Micro-Word, check the printer settings.
To test the machine, just load paper in one tray and remove all other paper from the other trays.
Run a copy using the glass only, not the document feeder.
If it copies good, then try running a documents from the document feeder in the same exact way the paper is loaded in the tray.
Check the paper trays menu to see how they are set up to print.
Good luck.
MACHINE IS NOT GETTIN BOOT,NETWORK
The machine does have a network card on the back. If there is no connection, a bad board may cause this problem.
Make sure your software is loaded correctly and check the parameters, settings, network settings.
If the software needs to be loaded on the machine a service call needs to be loaded by the service representative.
My DC440ST have a code U4-2 fuser overtemperature,
You will need to either rebuild or replace the fuser. Much easier to replace.
Google a business called "the parts drop" . Call and talk to Britt. He will have what you need.
But a U4-2 normally means the thermistors and thermostats need replaced, normally by that time the heat and pressure rolls are worn out.
Which is why I say an entire new fuser would probably be the best route.
Just a couple of thumb screws to replacing it.
Scaner not working
This will require a service call by Xerox.
This maybe broken or worn out gears and even a ciruit board to go out.
Check to see if the parts and labor are included with the call charge.
If it is take the service call and let Xerox repair the machine.
