20 Most Recent Xerox 8825 Copier Questions & Answers
2answers
XEROX 8825 ERROR LL-22 PLEASE HELP !!!
pls clean the corona wires and charge assembly
2/3/2020 12:40:37 PM • Xerox 8825... • Answered on Feb 03, 2020
0answers
2answers
Xerox 8825 error "LL-90 Call for assistance". Will not print.
replace the toner cartiage
7/2/2016 6:06:53 AM • Xerox 8825... • Answered on Jul 02, 2016
510 wide format printer is getting error code LL-7A please
The manual on page 144 says this about LL codes: f91147ca-449e-4715-8d14-2ce4e9942cfe.png
6/26/2014 6:11:33 PM • Xerox 8825... • Answered on Jun 26, 2014
0answers
0answers
8825 price
Be the first to answer 12/11/2013 2:57:37 PM • Xerox 8825... • Posted on Dec 11, 2013Be the first to answer
8825 wide format printer is getting error code LL-55 please can u solve the problem if so reply my please
powersupply board is problem change it
5/23/2013 2:20:04 PM • Xerox 8825... • Answered on May 23, 2013
8825 or 8830 jumbo xerox is it good and i want to know prize
RS. 350000
5/23/2013 2:11:51 PM • Xerox 8825... • Answered on May 23, 2013
0answers
Low fuser oil
Be the first to answer 1/22/2013 4:02:18 AM • Xerox 8825... • Posted on Jan 22, 2013Be the first to answer
0answers
How do I clear a
LL-10 code means : Paper transport or Xerographic module are disconnected. LL' codes can indicate a wide range of problems. Here is a quick list: 'LL-05': Fuser Web end of life. 'LL-06': Fuser web motor not seen turning. 'LL-10': Paper transport or Xerographic module are disconnected. 'LL-12': Drum motor failure. 'LL-21': High Voltage Charge failure. 'LL-22': High Voltage Transfer failure. 'LL-30': Cutter fault. 'LL-41'through 'LL-45': Fuser problems. 'LL-50': Problem with "Bulk Power Supply," which provides 26VDC. 'LL.60': NVM (Non Volatile Memory) failure. 'LL.90': Overtoned condition. 'LL.91': Low Toner problem. -------------- For your problem remove the drum unit and paper tray and reinsert. Check if paper is not inserted properly or there is no paper.If paper tray is proper then check the drum unit.It should be lose.Remove and reinsert drum unit. ((((((* The Module Loop Interlock is a circuit which sees that both the Media Transport Module and the Xerographic Module are installed (if either is missing, the interlock isn't made.))))))))------------ This will help.Thanks.Helpmech.
12/18/2010 6:31:27 PM • Xerox 8825... • Answered on Dec 18, 2010
Not printing on edge of paper
pls check the developer qnty
12/12/2010 3:11:37 PM • Xerox 8825... • Answered on Dec 12, 2010
37 questions posted
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Xerox Office Equipment & Supplies
Most Popular Question
8825 or 8830 jumbo xerox good want know
  • Office Equipment & Supplies
