20 Most Recent
Macally Bluewave BlueTooth Wireless Stereo Headset for iPod Wireless Headset Questions & Answers
How do i pair my bt4517 headset?
you need to switch on the bluetooth on your mobile. then switch on the headset (by holding the call button for few second). you will see blue light flashing. now to pair them with ur mobile click the volume controls (+ and -) on heatdset together for two second and search for the bluetooth head set in ur mobile it will detect it as BT*** just give the pass code 1234 and there you go. hope this helps. the instruction is there in the box!!!
Got this elsewhere - tried it - it worked !
Blue wave wireless headphone
Please take out the batteries from the dongle and headset for 20 minutes.
Insert a new battery into the dongle, plug into your player and turn it on.
Wait for 2 minutes, insert another new battery into the headset and turn it on.
It will take about 2 minutes to connect each other at first time.
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
on Apr 19, 2024
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
