20 Most Recent
LG GSA-H42N 18x DVD RW DL IDE Drive (Black) Burner Questions & Answers
How to write a dvd to dvd
use any dvd burning software ... choose option "copy dvd" and after that give the source and destination the same..ie source and destination should be the same..this allows the dvd to make a copy not on the hard disc...and after copying the source dvd, the drive ejects and insert new blank dvd.. and you are done
My LG DVD RW can not play DVD
Are you sure that your ROM can't play the disc or is it that you don't have a program to play the disc? To my knowledge Windows XP didn't come packaged with a DVD Decoder program; except for XP Media Center. There are some FreeWare programs out there that you can download, or you can pay for the program that decodes DVDs so that you can watch them.
If your DVD isn't recognizing any type of DVD that you put into the ROM, then try playing a CD\DVD player cleaning disc in it. If that doesn't work, then you will probably have to get another DVD-ROM.
I want driver
Hi, if it is not "plug and play" go to the manufacturers website,
if it is a reputable make the drivers should all be there
DRIVER FOR LG MULTI SUPER DVD BLACK
Start-Control pannel-System-Hardware tab(I don't know how it appears in english, bcause I have a Spanish O.S)
Then you will se a list of your hardware.
Look for DVD-CD drives and double clik to see if a driver is installed and corresponds with your hardware.
You have few possibilities:
1) an exclamation mark appears near the drive: this means that the driver was not properly installed: In that case double click and sear for a new driver
2) You have a driver that doesn't correspond to your harware:
Do the same as 1)
2) The drive installed is the correct one: The problem can be a hardware one.Note the exact name of the driver and the version and go to LG site and look for a new one
3) No DVD/CD drive appears in the list: Go to Start_control pannel_ add hardware and let windows search for your DVD and install the apropiate driver.Stay connected to Internet to let the system search on MS .
Hope that will help
Hi I had a white
It is the ring that comes in a new CD or DVD spindle. It was stuck to a disc that you put in the player and you didn't notice it.
I would guess that either the drive made a horrible noise when you tried to access the disc or it would fail to read or burn as the disc was off balance.
Throw it away and look at the first disc from a new spindle before you put it in. It happens to everyone once or twice. It can damage the drive though so if it didn't kill it feel fortunate and use caution in the future,
Cheers.
Dvd & cd not burned.
what sort of burning software are you using?
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs:
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. oryou might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
I have LG Super multi
Test your PSU or replace it if your power supply units fan
is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or
to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including
electrical extensions,IDE,SATA
the leads from your
((motherboard to your hard drive)) make sure they have a secure connection
and are not faulty or just replace them they could be faulty
make sure all leads that
are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections
and are not faulty even the electrical extensions or just replace them they could
be faulty a computer
needs its connections to continue its cycle and have an end so any faulty leads
will end up with a computer error
another
possible reason could be a memory dump you might be running to many programs at
the one time placing to much strain on the CPU also you might not have enough
RAM random access memory to check what is running when your computer is running
scroll to the bottom toolbar right click select task manager applications and
processes if you see something you dont need running select end now to check
how much ram you have click start right click on my computer select properties
you will see all of your computers details another way to check
how much RAM you have click start all programs accessories system tools system
imformation all of your computers imformation will be there
try uninstalling a few unnecessary programs then click start run
type cmd then type chkdsk/r/f which will scan for and attempt to fix
any bad sectors and automatically fix any corrupt files on your hard drive this
will schedule on a restart don
DVD Drive Can't Detect Any DVD or CD
hi there, this could be windows system glitch. please follow troubleshooting steps below
- Click Start , and then click All Programs.
- Click Accessories, and then click Run.
- Type regedit, and then click OK. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
- In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
- In the right pane, click UpperFilters.
- On the Edit menu, click Delete.
- When you are prompted to confirm the deletion, click Yes.
- In the right pane, click LowerFilters.
- Exit Registry Editor.
- Restart the computer.
Let me know if you need more help. Thanks! If you need further help, reach me via phone at
https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Nem ir a hl-dt-st dvd-ram
im not sure exactly what this problem is but i guess you are have problems with your burner
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Hi
i have a dvd rw
make sure that the jumper seting is right if it is the first thing it should be on master setting if not slave for sec.jim
How to locate the jumper
The jumper is in the back of the unit, near the IDE interface. The jumper allow you to select one combination of 6 pins placed in 2 rows. Selection can be made only vertically.
How to install
When you install a DVD RW; a few things to consider. Locate a IDE connection to your motherboard. (do you need to share with the cdrom already in the pc or not?) You need to ensure the jumpers are set right. there are 3 spots on the back labled "CS/MA/SL" (on the lg, these are typically stamped into the top) The "first" drive on the wire is "ma" the second is 'sl" or ensure both are set to "cs" (which is cable select) this will ensure they can be detected. Hook up a power connection to the drive (use anyone that is free) OF COURSE, ensure your computer is OFF before you do this.
Cd not found
make sure that the jumper of the CD room is selected the slave position or use a seperate IDE cable for your CDrom and hardisk.good luck hope this helps you!
much appreciated if you click the 4 thumbs up button for my answer for your free question this helps me keep going.
