20 Most Recent
Kyocera Copystar CS-1635 Copier Questions & Answers
Maintenance light blinks
Enter "10871087" using
the numeric keys
Enter the U251 number using numeric keys.
Press the copy start key.
Select the Light exp. 3. using the exposure adjustment keys.
The count is cleared, and the indication for selecting a maintenance item No. appears.
Keycera machin have problem keycounter massage are given
Go to the service mode by 1087 1087 press 020 then press 25%% or 400% to on it. then press start. after few seconds machine will restart. same process with 021 also. note: first take down the setting list from 000 by pressing start key. this features will get the machine to default factory setting.
THE MACHINE INDICATE J11 WHAT IS THE PROBLEM
j11 indicates that the paper is not being fed from the paper cassette 2.
This can be caused by incorrectly loaded/thick paper. Cassette not correctly adjusted.
Paper feed rollers need to be cleaned or replaced. Blockage or parts failure.
On Feb 15 2014, 12:35 PM
sir if you want to make the copier as network copier then go for a print server. it will be cheaper and it will allow your machine in network. print servers are found in computer shops
How to reset my copier plz send me a solucation
whats the code man
if it is c600 then got diagonistic by presssing 10871087
then press 163
press start button 3 times to clear it.machine will restart .this is for fuser .
if u require to reset the drum then msg me
I am Thomas from South Sudan my Kyocera Photocopier 1635 Series error code : C6000.What to do sir?
Mr Thomas, this code means Fixing error, firsf switch on your Photocopier Machine then press 1,0,8,7 again 1,0,8,7 display will change will show u000. then press 1,6,3 press start key two times. machine will go off and on again. try that ,if will not work i will give you onather way.
Fixing part is errar
type 1087, 1087 when the machine is on until it shows U000. type 163, press Start, display will show CLE, press Start again. The machine will initialize and become ready for copying.
I have an error code
goto service mode by pressing 10871087.
then press 163
then start 4 times.the machine will restart and wola
