20 Most Recent
Frigidaire 12.8 cu. ft. Chest Freezer GLFC1326F Questions & Answers
Comes on kicks off no freezing
Hi Clifton - Make sure you have cleaned the unit's coils and behind the toe grille at the bottom/front of the unit. If the unit is not cooling, check to see if you hear or feel the compressor running. If you do not, contact a service professional immediately. If you do, and it is not cooling you may have a coolant leak or an issue with the internal sealed system of the unit and need a professional still. Try to clean it first however and make sure no vent on the inside of the unit is blocked by food items.
Freezer no cooling and compressor continues
low on gas has leaked check acces tube or valve or any solder joints for oil traces as this is common also check if someone has pierced inside the chest to defrost freezer as this would probably dammaged the evaporator
Frigidaire, chest freezer only 2 or 3 yrs old, was...
See if you have 120 volts at the compressor if you do do you hear any clicking sound at compressor if not replace compressor Start Relay/Overload if you hear clicking sound the compressor may be bad or Start Relay/Overload the only way to know is to replace the compressor Start Relay/Overload. If you do not have 120 volts at the compressor jump out the thermostat you should have 120 volts at the compressor now if not you may have a defrost timer Prob. if this is shelf defrost unit check timer turn knob to see if it starts.
Loading
You need to remember heat rises and cold air falls. The best way to load a freezer is to put meats on the bottom. They take alot longer to freeze and thaw and can save your stock if you have a power failure. Keep non-critical things like ice cream, ice, and other thing towards the top for quicker access.
Brand new unit, compressor noise.
Since I could get no one to tell me about new freezer compressor making buzzing noise while on, I had the store come a pick it up and give me my money back.
My Frigidaire up right freezer is showing an error code "FF" and is beeping. What is the issue?
Hey friend, thanks for your inquiry!
Within your Frigidaire freezer the error code "FF" stands for freezer failure. I would perform a reset on your appliance which can be done by either unplugging the power cord or flipping the household circuit breaker. Once the freezer has come back on you should be able to push the "Down" button three times to start it back up.
If that does not correct the issue Please respond back I would like to assist you with any additional information. Hope this helps to some degree. -Matt
