It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If not the pump must be checked for clogging.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
Thank you for contacting fixya.com.
Pull the dishwasher out, unplug it. Look on the back of the top panel and there are screws. Undo this then slide the top towards the front of the dishwasher and it will lift off. In the middle front top there is a small plastic arm with one nut, undo this then the door will open. Then ascertain if you need a new latch mechanism. Please get back to us if you have further query else please accept the suggestion.
66 questions posted
42 Questions
25 Questions
