20 Most Recent
Bunn Dual SH DBC Questions & Answers
Only brewing half
Remove and clean the spray head above the filter basket. If it still under fills, there could be a problem with the dispense solenoid valve.
How many ounces or cups
For a half gallon of brewed coffee you should start with a "volume" measure of 10 oz. The reason I recommend a volume measure is because the weight could be completely different using light roast or dark roast coffees. Brewing by volume you can have consistency throughout. The main object is to have the same surface area of grounds for your brewing. The 10 oz. volume should equal between 3.75 and 4.25 ounces by weight. Adjust by taste to your palette but don't sway too low in amount of grounds, otherwise you will stand to "over-extract" and your coffee will taste bitter and will have no body or mouth-feel.
Breaker keeps tripping
Hello. Here is what I think, not looking at the unit myself, I would start by checking the heaters, both of them, and the heating circuit for a short to ground through the water, here is a link to the manual,
http://www.bunnomatic.com/pdfs/commercial/manuals/41746.0000.pdf
and from page 34 on has the proper diagrams. An electrician should be able to handle a resistance check of this circuit, with a multimeter. If not you need a repair person that can, look in your phone book for Restaurant repair service.
The other thing I have seen with these, is the solenoid coils have shorted out, and cause intermittent problems, but these usually blow the main board, this would be evident by black scorching either on the front or back of the board.
Hope that helped, and thank you.
Ask me if you need more help.
I cant see my BUNN BT Velocity date code on my brewer I was told it is 6 digits... it starts with what number??
To locate the date code on your BUNN BT Velocity brewer, you can try the following:
- Check the bottom or back of the brewer: Look for a label or sticker on the bottom or back of the machine. The date code is typically printed on this label.
- Inspect the sides or inside the brewer: In some cases, the date code may be located on the sides or inside the brewer. You may need to remove any panels or covers to access the label or sticker.
- Consult the user manual: If you have the user manual for your BUNN BT Velocity brewer, it may provide information on where to find the date code. Refer to the manual for specific instructions or contact BUNN customer support for assistance.
If you are still unable to locate the date code on your brewer, I recommend reaching out to BUNN customer support directly. They will be able to provide you with accurate information and guide you in finding the date code on your specific model of the BT Velocity brewer.
Bunn my cafe mcu red light flashing. Water does not heat. Water will run out if brew button pushed, but of course it is cold
I have the identical problem, and I noticed it this morning after there were 2 very brief (seconds) power outages the previous night. Reading around the internet I read that the fuses inside the unit are the likely culprit, and need to be replaced. You can buy fuses made by others, for this unit. But not from Bunn. And there are video instructions around that show how to do it. The fuses are crimped on, not soldered. Mind you, I haven't tried to do this, yet, but that's what I read. Good luck!
