20 Most Recent QMemory One Touch Backup 250 GB USB 2.0 Hard Drive Questions & Answers
If you are using Vista, I seriously doubt it will allow you to use the image. Normally any Windows program will not allow you to do something like that from within windows. The system image backup is meant to restore the image, which means completely copying and overwriting everything on the hard drive - which Windows will not allow while in use. If you boot from the Vista setup disk, then you should be able to restore the disk from there.
QMemory One... | Answered on Oct 03, 2017
Try a new USB cable first, you can likely find what you need on eBay. It should be a standard USB cable.
QMemory One... | Answered on Oct 22, 2016
If you are having only one drive, means the drive contain OS and data . it wil loose. If you are having separate drive for data and OS and format only C drive . then data will be secure. Better keep keep at least two drive and one is for OS and another one is for data.. Hope you will succeed
QMemory One... | Answered on Dec 31, 2009
Click start control panel administration tools computer management device manager scroll through all of your devices or for Windows 7 click start right click on computer select properties in the left pane device manager scroll through all of your devices. If you see a yellow question / exclamation mark ? ! or a Red X you will need to update the drivers for this device right click select update driver/reinstall driver software. If you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver If you computer came with a motherboard disk the drivers could be on it. or you might have to download them Rather doing a driver hunt which can take hours. http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 This might take some time being a freeware driver solution Note: The Driver program will find all of your outdated drivers This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point. Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated. also at cnet http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: Motherboard name sound drivers. Place a tick in either windows software or all software box. You might have to try a few times to get it right. http://download.cnet.com/drivermax/3000-18513_4-10572602.html Windows 2000/XP/Vista/7/8 free driver program http://download.cnet.com/drivers-for-free/3000-18512_4-75548155.html Windows XP/2003/Vista/Server 2008/7/8 free drivers http://www.downloadcollection.com/device_doctor.htm Device Doctor is a freeware Windows application that scans your computer hardware and checks to see if there are new driver updates available for your devices. It also locates drivers for Unidentified Devices in the Windows Device Manager. This tool was designed to be very simple and easy to use http://www.innovative-sol.com/drivermax/ free program, paid update available Hope this helps.
QMemory... | Answered on Jan 26, 2013
when you change a hard drive from one PC to another you have to do a fresh install. The problem is caused with the registry. In other words, the hard drive remembers where is was conntected to and records all of the hardware on your PC to a sepecial datebase called a registry, when you start it up it looks for all of that hardware and if its not there it fails to boot.
rmatheson@wowway.com
QMemory... | Answered on Sep 30, 2008
Hello Victor, you must search in the internet search engine you have (Chrome, Mozcilla or the one you have), Gmail, you open it and it will appear to start session, put your Gmail address and your password and login, surely you will ask that you confirm that you are the owner of that account, follow the steps and ready
I hope you can solve your concern
Greetings Franco Dosil
Hola V?ctor, debes buscar en el buscador de Internet que tengas(Chrome, Mozcilla o el que tengas), Gmail, lo abres y te va aparecer iniciar sesi?n, pones tu direcci?n de Gmail y tu contrase?a e inicias sesi?n, seguramente te va a pedir que confirmes que sos vos el due?o de esa cuenta, sigue los pasos y listo
Espero que puedas resolver tu inquietud
Saludos Franco Dosil
Computers &... | Answered 1 minute ago
Hello Victor, you must search in the internet search engine you have (Chrome, Mozcilla or the one you have), Gmail, you open it and it will appear to start session, put your Gmail address and your password and login, surely you will ask that you confirm that you are the owner of that account,follow the steps and ready
Hola Victor, debes buscar en el buscador de internet que tengas(Chrome, Mozcilla o el que tengas), Gmail, lo abres y te va aparecer iniciar sesi?n, pones tu direcci?n de Gmail y tu contrase?a e inicias sesi?n, seguramente te va a pedir que confirmes que sos vos el due?o de esa cuenta, sigue los pasos y listo
Computers &... | Answered 3 minutes ago
Yes sure you can. But I need to remind you that after you repair your device, all of the files may be lost 'cause repair it just like formatting it.
Moreover, when you get your repaired device, you'd better not put any new data like photos, songs, etc. into it. Once you do this, the data overwritten will be caused and you will lose the chance to get the files back.
Actually such repairing, formatting or deleting will not really may your files lose forever. It just frees up the space of the so called deleted files so that the space can be used by the new files. Once the new files take the space, the deleted files are really deleted forever. That's why I ask you don't put any new files into your device. Maybe this post can help you a lot:
Mac Files RecoveryRecover Mac Files with Ease
Computers &... | Answered 3 hours ago
device only works with projectors. Can not be used in a PC or Mac computer
Computers &... | Answered 4 hours ago
Your screwed.
OK seriously, there's usually a box that all websites have that you can check and they will send you a temporary password to your registered email address. You use this to log on and then go into your profile and reset the temporary password with a new one.
Computers &... | Answered 5 hours ago
There are several other cleaners that you can use, and multiple ways to recover your activation key, you can use your original receipt, or can call 1-877-805-1027 for toll free assistance.
Computers &... | Answered 8 hours ago
Phone the number on the back of the card! It is the only way unless you have an online account and can change it in settings.
QMemory One Touch Backup 250 GB USB 2.0 Hard Drive Logo
5 questions posted
Top QMemory Computers & Internet Experts
Alun Cox
Are you a QMemory Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • QMemory Computers & Internet
Most Popular Question
qmemory speed
  • Computers & Internet
