20 Most Recent Lacrosse La Crosse WS-2800 Series Wind Cup Replacement Questions & Answers
I tried this and it worked fine
FACTORY RESTART:
A Factory Reset will erase the connection between the Display and the Thermo-hygro sensor and allow a fresh connection to be re-established. It is recommended to have the display and all sensors 5-10 feet apart for this restart.
ENTER PROGRAM MENU
Press and hold the SET button until you enter the program menu. Press and release the SET button until you see 'rES oFF' flashing.
FACTORY RESET ON
Use the UP ARROW key or DOWN ARROW key to turn rES on.
CONFIRM & COUNTDOWN
Press the SET key to confirm and a countdown timer will begin counting down from 127. When the timer displays dOnE, you must remove the batteries from the display for 10 minutes
REMOVE BATTERIES FROM THERMOHYGRO AND RAIN
While the batteries are out of the display, also remove the batteries from the Thermo-hygro sensor and the Rain sensor. Wait 15 minutes.
GENTLY KEY THE WIND SENSOR
Gently key the wind sensor one time to activate the sensor.
INSTALL BATTERIES INTO THERMOHYGO AND RAIN
Insert fresh alkaline batteries into the Thermohygro sensor and Rain sensor make sure to check polarity with the markings on the battery cover and inside the battery compartment. Wait 2 minutes.
INSTALL BATTERIES INTO DISPLAY: Insert fresh alkaline batteries into the Display. Make sure to check polarity with the markings inside the battery compartment
15 MINUTES: Wait 15 minutes for the outdoor weather data to display. If the outdoor data displays dashes after waiting for 15 minutes, repeat the steps of restart.
AZ Road Runner
Lacrosse La... | Answered on Nov 02, 2012
FOR THEM BOTH TO SYNCH YOU HAVE TO PUT THEM TOGETHER FOR A WHILE. ALWAYS USE LITHIUM BATTERIES FOR THE OUTDOOR UNIT TOO
Measuring Tools... | Answered on Nov 02, 2019
try the makers website or google
Measuring Tools... | Answered on Oct 27, 2019
Give details about the clock. Is it mechanical or electronic?
Measuring Tools... | Answered on Oct 25, 2019
They are advertised as 50 foot range, but the accuracy starts falling off past about 35 feet
Measuring Tools... | Answered on Oct 11, 2019
A hookah is an instrument used to smoke shisha. Shisha is a type of flavored tobacco! Read more on Shisha Heart
Measuring Tools... | Answered on Oct 10, 2019
can the battery be replaced. If so, how?
open the cover on the back of the device. this is done by squeezing the cover of the battery sector slightly. then remove the old batteries and replace the new ones (I assume you have the AAA) and put the new ones in keeping with the polarity for the device to work properly and then close the battery compartment cover in reverse order
Measuring Tools... | Answered on Sep 29, 2019
Lacrosse La Crosse WS-2800 Series Wind Cup Replacement Logo
2 questions posted
Top Lacrosse Measuring Tools & Sensors Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Lacrosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Lacrosse Measuring Tools & Sensors
Most Popular Question
ws 2800 rain not displayed
  • Measuring Tools & Sensors
