20 Most Recent
Intel DQ965GF Motherboard Questions & Answers
Intel core 2 duo d945gcr
Click the below link and download all the drivers for your Board.
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+965+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DQ965GF/
INTEL DQ965GF-Motherboard boot up problems
check all leads from motherboard to hard drive including electrical extensions and all of your cd/dvd drives make sure connections are secure dust free and not faulty
computers need all power and data to travel through every working device and to finish its cycle
so any faulty lead will end in computer error or shutdown or fail to boot
make sure your computers RAM modules are securely seated with no dust in the sockets also the Cmos battery has charge and seated with no dust in the sockets
some motherboards cmos batteries are soldered in
might be getting hot check your CPU make sure it has a thermal paste and a dust free and secure seating
hope it helps
Hi there
I have just re
Ok my brother
TO slove your problem you
enter here.
then go to drivers back up page .
then make like in the page to get your drivers back up .
thank you
Just installed the dq965gf motherboard and nothing
Double check the power connection to the hard drive. Also, try a different power connector.
Then try just the hard drive without the CD plugged in.
I've seen systems not boot if the CD has a problem.
I don't know if you have an add-on video card, but if you do, be sure it's seated firmly. This, too, will prevent a boot.
When i format my lap i miss my sound drivers, i
Do you have the original drivers?
do you know what sound hardware you have( check the system in the control panel)
Or if you need it immediately, use a generic windows driver( when it asks you what driver you want to update to, choose from the list; it will show some generic driver)
question. do you have a PC runnig windows, apple, linux, solaris?
is it an internal sound card, or you upgraded it ?
if you did upgraded it, you need to get into your bios, and choose the option to disable the internal sound card( usually it tels you when you boot, it say press "xxxxx" for BIOS. be careful what you do in there.
hope this works, otherwise, clarify some more.
Hard to boot
Dear user,
As per your problem i like problem in your motherboard pl checkout with repairer vendor.
Regards,
Ravindra Shah
How to download sound driver
hello
download from this site
drivers.softpedia.com/get/SOUND-CARD/OTHER-SOUNDCARDS/Intel-DQ965GF-Sigmatel-92XX-Audio-Drivers.shtml
Motherboard
Hi T, you know you can not run two different types (Speeds) of memory at the same time? Please re-check page 14 in your manual. Make sure your current memory timing for 667MHz is set to 5-5-5. Lost display, incert your old memory & reset the cmos jumper page 52 in your manual.
