20 Most Recent
Biostar P4M800 Pro-M7 Socket 775 mATX MB w/Video Audio (ETKMBB-P4M8P-M7) Motherboard Questions & Answers
I need the bios of biostar p4m800-m7
best is leave it alonethat P4 mobo was sold in 8 + modelsgetting the wrong bios is going to brick the PC.only get bios from this OEM called BIOSTARand it is too old.those old trash P4 VIA CHIPSETS ARE NOT SUPPORTED FOR YEARS.8 HARDWARE VERSIONS. M7 HELPS BUT ONLY THEY CAN SOURCE THIS. m7A IS WRONG.THE MAKER IS IN TAIWAN. https://www.biostar.com.tw/app/en/search/search.php?search=p4m800-m7last one Aug ,3, 2007 for smart fan.good luck not bricking it, read the PDF bios there.see page there backup bios first.do that first to USB.
Get sound drivers
Hello DJ Shenon!
Biostar has all the drivers for your P4M800 Pro-M7 motherboard available for download on their website. The link for your motherboard is
P4M800 Pro-M7
It can't play any sounds
try to install the lastest driver for your motherborad
note: you should install only the driver for yours
Drivers needed
check u r mother model number. go to run and type
cmd and next type cd\.
then type systeminfo you will get system model: XXXXX and then type this system model in google for down load the drivers.
Getting Blue Screen of Death :
on windows xp???mybe some your hardware having problem??
1. try to check your memory.
2. your cable in side the PC
3. Or some of your hardware not support with OS your install
Replacing memory on the P4M800-M7 A motherboard
No. Just make sure that you two RAM modules have the same specifications (speed, clock).
If you don't know about that, then simply insert both RAM modules and start your computer. If Windows loads, then right click on MyComputer and go to properties. If it shows 1.5GB then you are OK.
If the computer fails to start or you hear multiple beeps it means that they are incompatible.
Replace the 512 module and insert the new one and try again.
Always remember to turn off the power and unplug the cable from the power supply before replacing RAM modules.
Motherboar fail, no video, power supply ok help
Firstly, remove the RAM and turn on the system, if you hear the beep sound continuously that means everything is perfect expect RAM.
Clean the track of RAM at both sides by pencil eraser completely.
Also clean the port of RAM.
Secondly reinstall the CPU with CPU FAN and also clean the FAN.
Third one is that remove all the add-on's card and than turn on the system.
Problem for Biostar P4M800 Pro-M7 Socket 775 mATX
I have the exact motherboard in a everyday desktop. I ran into this issue myself. The video card was bad. It didnt give me any error beeps either. So, I popped a used AGP nvidia geforce 5200 in the slot and bam, it was back up.
However, make sure your hard drives are spinning. If they are not, there might be another issue at hand...
Hope that helps and let me know what you find
Audio driver for biostar u8568 pro
Hi...
You need to open this site the model that we can provide are related to your model, that driver can support also to your model.
http://www.howtodrivers.com/model551665.html
Good luck !!!
Regards
PCmania
No POST No Beeps
hi,,,
i think your problem sir is the Bios ,,
1: after trying to clear the CMOS, you can check the manual for that,,,
if not ,,
2: please just try to replace it with an updated one from another exact Mainboard ,,,
i think it will work perfectly :)
thankx very much,,,,
