20 Most Recent
Amana AGR5715QDS Gas Kitchen Range Questions & Answers
How do you use self cleaning
Before you go working too hard to get
you oven to go into the self clean mode(self destruct)....check out
this tip...
Self
Cleaning Oven Problem
heatman101
Wish I had read this first. I never would have used the self cleaning
option. Thanks for the info!!
My oven won't heat up exept on broil.
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Baking oven won't ignite
Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
I have a code on sceen 5a6 what dose that mean
What's probably being displayed is actually "Sab". This is an indication that the range is in "Sabbath Mode". This mode is set for those religions that honor the sabbath and disables the oven for about 72 hours. Unplugging the range will not clear this. It can sometimes be set accidentally following a power outage or inadvertently hitting the wrong button on the control panel.
If the model number you have this listed under is correct, you can cancel Sabbath Mode by pressing and holding the "CLOCK" button on the control panel for 5 seconds. If you refer to your Owner's Manual the instructions are listed under the Oven features section.
If you do not have a manual, you can go to managemyhome.com and download one for FREE.
If you have any questions, please let me know. If the model number is incorrect, please post back with the correct model number so that I may provide you with better assistance. I hope you find this information helpful.
Stove spark lighter won't shut off
The spark ignitor needs to be replaced. You can get it at your local appliance repair store or online at repairclinic,com. That is the way it tells you that it is bad by constantly clicking
We recently moved, when we got to our new house we
i would first try the breaker it sounds like you only have half the power coming to unit and the light and clock will work but the heating componets will not as they require the full 220-245 volts
it sounds very odd that everything as far as burners and elements are out but you have a clock display and light... you have lost one of the legs of power somehow...either the double breaker is not fully on and may require turning off oven breaker and resetting or half the breaker has failed... a sure way of testing would be to pull out and with a volt meter test to see that you have 220-245 volts coming to oven,,, hope this helps out repost if anymore questions...
