20 Most Recent Seagate Momentus 5400.3 Hard Drive Questions & Answers
Cannot boot from Momentus Ultra ATA 160 GN HDD
it can only clone the windows files and folders there is other files located on a hidden system on the hard drive, when you install and new hard drive these file are fixed to the drive. to make a bootable drive you need to install these files from a windows disc then add clone files over the top so these files don't get deleted.
5/27/2017 4:13:45 AM • Seagate Momentus... • Answered on May 27, 2017
I have a seagate momentus
Configuring the BIOS
After completing the drive installation, restart your computer. Your computer
may automatically detect your new drive. If your computer does not
automatically detect your new drive, follow the steps below.
1. Restart your computer. While the computer restarts, run the system
setup program (sometimes called BIOS or CMOS setup). This is usually
done by pressing a special key, such as DELETE, ESC, or F1 during
the startup process.
2. Within the system setup program, instruct the system to auto detect
your new drive.
3. Save the settings and exit the setup program.
When your computer restarts, it should recognize your new drive.
That should work ya long haired hippie. give me a shout this weekend, M.Y. (puff puff pass *****!)
1/3/2014 4:55:04 PM • Seagate Momentus... • Answered on Jan 03, 2014
0answers
I just pulled a 2.5
you should download Seatools on a working machine.....its a diagnostic program for Seagate drives.
Let it scan the drive in question, because it sounds like it could possibly be bad. The jumper settings dont come into play when hooking it up via usb!
8/14/2011 7:58:23 PM • Seagate Momentus... • Answered on Aug 14, 2011
Seagate external drive Momentus 5400.3
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
7/8/2011 10:55:10 AM • Seagate Momentus... • Answered on Jul 08, 2011
No just plug it in to the extra plug on the board.
2/19/2011 8:55:48 PM • Seagate Momentus... • Answered on Feb 19, 2011
Beeping no access to drive
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off. make sure that your RAM is securely seated test or replace all the leads that attach to your hard drive make sure the connections are secure including electrical extensions + IDE,SATA the ones that attach from your ((motherboard to hard drive)) make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ? hope this helps
1/31/2011 12:31:04 AM • Seagate Momentus... • Answered on Jan 31, 2011
I want a much larger
It looks like your current drive is a 80GB 2.5" EIDE.
The maximum you could easily get is probably 320GB for $90-100.
The price is high as SATA drives are now the standard.
Have you considered getting a 2.5" 500GB external drive, connected by USB.
The external 2.5" drives are powered off the USB and need no other connections
It would be cheaper and give you more storage.
You wouldn't have the difficulty of opening up your laptop, and if it's working OK now it's best to leave it that way.
1/30/2011 4:12:41 PM • Seagate Momentus... • Answered on Jan 30, 2011
Seagate Momentus 500GB hard drive
This is a typical hard drive failure scenario, please check if your computer has valid contract if so get your hard drive replaced.
If you have valuable data in your hard drive and willing to spend you can go for hard driver data recovery which is an expensive process.
1/5/2011 7:06:56 AM • Seagate Momentus... • Answered on Jan 05, 2011
I was given a seagate
Try connecting it to a different computer.
EXACTLY what error-message do you get?
When you double-click that entry in Device Manager, and click "reinstall drivers", allow Windows to connect to the Internet to look for a device-driver for the USB-to-disk-drive adapter (no device-driver is needed for the disk-drive itself).
12/11/2010 4:06:34 PM • Seagate Momentus... • Answered on Dec 11, 2010
My Seagate Momentus 5400.3 80GB
The disk-drive inside the enclosure is problematic.
Open the enclosure, to get the model-number and serial-number from the label on the disk-drive.
Then, access Seagate's web-site, to check the warranty-status of the drive. If the warranty still is valid, they will replace it, at minimal cost to you.
If the warranty has expired, purchase a new, compatible, disk-drive, and transplant it into the enclosure, to "resuscitate" your device.
10/30/2010 11:17:26 PM • Seagate Momentus... • Answered on Oct 30, 2010
I need the driver 4 this hard disk.
Hard Disk driver is automatically installed by the operating system when you connect it to your computer. So there is no worrying about that.
12/18/2009 11:32:10 AM • Seagate Momentus... • Answered on Dec 18, 2009
Formatting seagate hard drive #5400.3
reformat is automatic then it will divide ur hd then install os
8/13/2009 6:11:43 PM • Seagate Momentus... • Answered on Aug 13, 2009
How do i format the seagate 5400 160 gig hard drive?
your new drive.
There ya go ya tubby *****.Give me a shout this weekend, Mike
4/16/2009 1:32:13 AM • Seagate Momentus... • Answered on Apr 16, 2009
Seagate 80 GB laptop hard drive not appearing in My Computer
i suggest u to re instal u r windows........win-xp-sp2
remember- dont keep 2 operating system on u r hardisk man
dont forget to tell me u r problem solved or not
best regards & best of luck..
10/30/2007 8:08:13 AM • Seagate Momentus... • Answered on Oct 30, 2007
Seagate momentus 3 60gb problem
What software did you use for the cloning?
Ghost is the preferred method.
Be sure to choose a disk to disk clone, not a partition clone.
It sounds like you may have created a 20G partition and left 40G unallocated.
Partition Magic may also take care of the problem, if you have access to a copy.
10/16/2007 7:23:10 PM • Seagate Momentus... • Answered on Oct 16, 2007
Unlock hard drive password
Primary Hard drive or external ,usb hard drive ???.... Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Windows Advanced Options Menu Please select an option: Safe Mode Safe Mode with Networking Safe Mode with Command Prompt Enable Boot Logging Enable VGA mode Last Known Good Configuration (your most recent settings that worked) Directory Services Restore Mode (Windows domain controllers only) Debugging Mode Start Windows Normally Reboot Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select safe mode with command prompt Click start run type cmd press Enter black screen should open DOS mode this will vary depending on your operating system type in net user username For eg. If you want to change administrator password , type net user Administrator It will prompt you to enter the new password. Enter the new password and the password is changed http://wiki.ljackson.us/Control_Userpasswords2 if this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password Windows Password Recovery Basic http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free. http://download.cnet.com/lazesoft-recover-my-password/3000-18501_4-10973339.html Lazesoft Recover My Password Home Edition is a very easy to use Windows password recovery freeware
9/8/2013 7:48:25 PM • Seagate Momentus... • Answered on Sep 08, 2013
Seagate Momentus 5400.3 Hard Drive Logo
20 questions posted
Top Seagate Computers & Internet Experts
Sean Wright
Sean Wright
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Momentus Seagate
  • Momentus Seagate
Most Popular Question
seagate momentus 5400 3 80gb
  • Computers & Internet
