20 Most Recent
Gigabyte GA-945GM-S2 (0818313003065) Motherboard Questions & Answers
The mother board is hot
Possible cooling fan problem.make sure the vent ports are clear of lint,dust etc...do not use compressed air to blow out vents,,often this will blow debri directly into the hard drive use a Q-tip....cooling pads or 15 dollar cooling stands may keep it cool until you find someone to take it apart and see if the fans or fan is bad.
6/7/2012 7:24:22 AM •
Gigabyte...
Answered
on Jun 07, 2012
At first my computer cant
Restart the system and then press delete key when the computer start up then set the first boot to CD/DVD ROM then press F10 (save) and follow the instruction "press any key to boot from CD/DVD ROM after that First try to repair and if it's not satisfy. Please to format your Hard Disk
Hope it'll be helpful to you
All the Best!
6/30/2011 11:31:24 AM •
Gigabyte...
Answered
on Jun 30, 2011
Front cables order
In case you mean the front panel cables, here is the part of the manual for these connections:
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
2/10/2011 4:17:20 PM •
Gigabyte...
Answered
on Feb 10, 2011
I need to install all
Hi there, welcome to FixYa!
Below is a link to where you can download drivers for your motherboard:
Click on the tab Downloads and Select your Operating system from the drop down box:
http://www.gigabyte.com/products/product-page.aspx?pid=2331&dl=1#dl
hope this helps,
levibit
12/14/2010 5:44:10 AM •
Gigabyte...
Answered
on Dec 14, 2010
My sound does't work
if you mean that you cant get any sound on your computer
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
11/25/2010 8:41:44 PM •
Gigabyte...
Answered
on Nov 25, 2010
HOW TO CONNECT FRONT AUDIO PINS
the connector is marked F_audio and it is located directly behind the rear facing audio jacks. should be only one plug either marked "hd audio" OR "ac97 audio". some cases are setup for either, but you only need one of them depending on what your motherboard supports.
11) F_AUDIO (Front Audio Connector)
This connector supports either HD (High Definition) or AC97 front panel audio module. If you wish
to use the front audio function, connect the front panel audio module to this connector. Check the pin
assignments carefully while you connect the front panel audio module. Incorrect connection
between the module and connector will make the audio device unable to work or even damage it.
For optional front panel audio module, please contact your chassis manufacturer.
By default, the audio driver is configured to support HD Audio. To connect an AC97 front panel
audio module to this connector, please refer to the instructions on page 72 about the software
settings.
Pin No. Definition
1 MIC
2 GND
3 MIC Power
4 NC
5 Line Out (R)
6 NC
7 NC
8 No Pin
9 Line Out (L)
10 NC
AC'97 Audio:
Pin No. Definition
1 MIC2_L
2 GND
3 MIC2_R
4 -ACZ_DET
5 LINE2_R
6 FSENSE1
7 FAUDIO_JD
8 No Pin
9 LINE2_L
10 FSENSE2
3/28/2010 4:47:01 AM •
Gigabyte...
Answered
on Mar 28, 2010
Warranty
contact Gigabyte at www.gigabyte.com and ask them directly. As they do not post it in specifications.
Thanks,
Lee
3/9/2009 8:51:11 AM •
Gigabyte...
Answered
on Mar 09, 2009
