20 Most Recent Intel Motherboard, 945GC, Core 2 Duo, S775, 800MHz, MATX, Max 2GB DDR2, PCIEX16,2PCI,FENET,Vid,Aud,SATA3Gb (BOXD945GCCR) Questions & Answers
8answers
Is a HP Pavilion MCP73M01H1 (Napa) the same as a Foxconn M7PMX-S?
oh wow. Why would the lady say such an ignorant thing with such conviction. This is just nonsense as we all know companies outsource all the time, precisely Retail driven, close to the end user companies like HP and Dell. PRODUCING is not the same as contracting out a set of mobos like the gentlemen correctly suspected of being the same as a foxconn model. I happen to have an HP with a foxconn mobo (and to the guru lady, it seems to also have Nvidia's signature, so really, what you see here, is Nvidia provides tech, Foxconn manpower and efficiency, and HP sales and marketing and the product sells, but suggesting HP which cant get to the phone to keep up support go out and actually manufacture their own mobos is the stuff of laziness).
To the gentleman asking, I have looked at the specs and your analysis seems to be right on. Here's another exact HP product (the one I own, given another HP special foxconn mobo name given the sheer volume of business these folks generate to foxconn. It does seem to get often confusing though and if I were you, and you seem to be quite familiar with hardware and the such, if you were to attempt a flash, make sure to backup first, that is the only harm you will cause to your computer, if you are not cautious even when you're certain. Here's the link to which I mentioned so many times:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=pv-71054-1&lc=en&dlc=en&cc=ca&lang=en&os=2093&product=3771694
1/23/2018 4:59:54 AM • Intel... • Answered on Jan 23, 2018
No display
Beep codes are usualy heard when there is a problem with either your display card or your RAM.
Your problem could possibly be a faulty CPU.
Does your CPU work in another board, or can you try another CPU in your board?
Regards,
Graemevm
5/24/2016 12:18:56 PM • Intel... • Answered on May 24, 2016
I cant install my zebronics geb 945 motherbord lan driver on windows7. plz help me
hello... this is your MB? http://downloadmirror.intel.com/15117/eng/D945GCCR_ProductGuide02_English.pdf Then the LAN chip is the 10/100 Mb/s) LAN subsystem using the IntelĀ® 82562G Platform LAN Connect (PLC) device.... Then the SEVEN driver are located here.... https://downloadcenter.intel.com/product/76951/Intel-82562-Fast-Ethernet-Controller Good luck...
9/8/2015 5:23:03 PM • Intel... • Answered on Sep 08, 2015
Mercury pi945 audio driver
http://www.mercury-pc.com/downloads_list.php?productid=751
5/19/2014 6:46:10 AM • Intel... • Answered on May 19, 2014
Multymidia audo controller driver
go to intel download support at discon boards then type in your board then download them you may want to update your drivers as well
3/24/2014 5:45:16 AM • Intel... • Answered on Mar 24, 2014
Motherboard can't display CPU fan moving fast no beep ram is ok no power supply problem keyboard LED flashing CMOS battary is new but display isn't showing anything
"no beep"... if your motherboard (mobo) has a system beeper and there is no beep on boot, the BIOS is not recognizing the keyboard so the computer will not boot. Reset the BIOS back to factory default. Unplug the computer, remove the battery for 10 minutes. Put it back in and try to boot. NOTE: be sure not to reverse the battery polarity! Usually the + side is up, but check your computer manual booklet. There is a small jumper on the mobo that you move to one side and back to original position again, which clears the CMOS settings. If you don't know where it is, see your computer manual booklet. If you still can't find it, just go with the above instructions.
3/6/2014 2:00:07 PM • Intel... • Answered on Mar 06, 2014
No disoiy 945GC
go to web site of intel download support type in your board then download drivers and manual same time ok
11/11/2013 6:28:20 AM • Intel... • Answered on Nov 11, 2013
No power on my intel dektop board
Replace the power supply.
8/14/2013 5:48:20 PM • Intel... • Answered on Aug 14, 2013
2answers
No display in my intel d945gcnl but power is on
check first your RAM memory and your video card. if ok all. try another ATX power supply.
7/22/2013 11:11:00 AM • Intel... • Answered on Jul 22, 2013
I want to download audio driver
Hello try the driver from here:http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=19472&lang=eng&OSVersion=%0A%09%09%09%09%09%09%09%09%0A%09%09%09%09%09%09%09&DownloadType=Install the driver and reboot.If the driver don`t work visit the pc`s (not the mainboard) homepage in seach for drivers.hope this will help you
12/7/2012 7:20:48 PM • Intel... • Answered on Dec 07, 2012
2answers
Can Foxconn MCP73M01H1 Napa-GL8E Motherboard
intel dg43gt mobo
11/28/2012 2:40:08 PM • Intel... • Answered on Nov 28, 2012
4answers
NEED INTEL CHENNAI SERVICE CENTRE ADDRESS?
Genune Chiplevel Service of Laptop And Desktop Mother Boards,Spares Contact: Multiware Info System, #163, North Usman Road, T.Nagar, Chennai-600017. CUstomer Support: 9841036469,9841602538,39.
5/31/2012 10:36:52 AM • Intel... • Answered on May 31, 2012
2answers
I have 2 DDR2 RAM
Hi ,
your computer is preset to handle so much memory , you need to find out how much it can handle ,you can do this by going online , and google your make and model of computer and read the specs on your computer .....................hope this helps ................good luck Roy ,
9/3/2011 8:43:40 PM • Intel... • Answered on Sep 03, 2011
0answers
Sound driver
Be the first to answer 8/8/2011 12:54:07 PM • Intel... • Posted on Aug 08, 2011Be the first to answer
Intel 945 mother board no
501, 5th Floor 4 Venkatanarayana Road Chennai
Chennai FSO Kuppu
501, 5th Floor
Chennai, Tamil Nadu 600017
India
Redington (India) Ltd. SPL Guindy House 95, Mount Road, Guindy Chennai 600 032, India. ... Phone: +604-659 9679. Fax: +604-658 9607, CPU - Boxed, Tray, Mobile; Server ...
6/18/2011 5:18:26 AM • Intel... • Answered on Jun 18, 2011
My computer is not starting
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working also it could be a dirty computer clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer and before you touch anything be sure to wear an earth strap hope this helps
5/30/2011 4:42:04 AM • Intel... • Answered on May 30, 2011
D945gcnl so late display problems?
Try downloading and installing the latest video driver.
You can download the motherboarddevice drivers from Intel WEB site. Select your model motherboard/device, andmake sure you select the Windows XP or Vista version of the drivers that matches your Windows operating system. Please click on this link andselect your model motherboard : - http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
5/14/2011 10:17:05 AM • Intel... • Answered on May 14, 2011
945gc his v3.0 Express Chipset Family drivers
i have lost sound after i have formatted my pc and installed WinXP, my PC is 945GC (HIS) v3.0 mother board core2duo. plz sugget the appropriate sound card driver for this
2/9/2011 10:08:05 AM • Intel... • Answered on Feb 09, 2011
0answers
Intel Motherboard, 945GC, Core 2 Duo, S775, 800MHz, MATX, Max 2GB DDR2, PCIEX16,2PCI,FENET,Vid,Aud,SATA3Gb (BOXD945GCCR) Logo
61 questions posted
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Intel Computers & Internet
Most Popular Question
foxconn mcp73m01h1 napa gl8e motherboard
  • Computers & Internet
