20 Most Recent HP Compaq nx7300 Notebook PC Questions & Answers
I need schematic for hp compaq nx7300. it's start
HP never published such a thing.! just buy a used MOBO off ebay, like what all other techs do now that all that is obsolete now. hint ,not sold at hp now, see proof here. see the N/A here, ? not available, believe it. http://partsurfer.hp.com/Search.aspx?type=PROD&SearchText=EN167UT that was one of like 100 versions of NX7300 sold world wide. i picked number 1.
2/10/2018 2:04:34 PM • HP Compaq nx7300... • Answered on Feb 10, 2018
My new battery will not hold a charge
Either the charge circuit in the laptop is faulty or the mains adapter is faulty. When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
10/11/2012 7:17:13 AM • HP Compaq nx7300... • Answered on Oct 11, 2012
Audio software
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -www.compaq.com/country/cpq_support.html
3/24/2012 2:55:01 AM • HP Compaq nx7300... • Answered on Mar 24, 2012
HP Compaq nx7300 Not booting up, the power light
Hi Percival,
Welcome to Fixya. If your having a blank or black screen on you laptop and you can see that fans are running and lights are on we need to check if this is a problem with the LCD or with the motherboard. I will provide you steps so that you will be able to determine which is the cause of the issue. Just a heads the problem is caused by a hardware failure.
To check if the problem is caused by a Motherboard or LCD you need to use an external monitor. Connect the external monitor to the laptop and tap FN + F4 on the keyboard. This command will toggle the external display. Check if you will be able to see a display on the external monitor.
If you will be able to see a display on the external monitor it means that the issue is caused by a bad LCD.
If you won't be able to see a display on the external monitor it means that the motherboard is bad. The motherboard is bad since the built in video card is not working and if you will replace the faulty video card of a laptop it means that you need to replace the whole motherboard.
If you have questions please let me know. Thanks for using Fixya.
7/2/2011 8:54:22 PM • HP Compaq nx7300... • Answered on Jul 02, 2011
How can instal or restore
download audio driver this link
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3310302&prodTypeId=321957&prodSeriesId=3310301&swLang=8&taskId=135&swEnvOID=2097
and double click instaalled file and see instructions
please vote me and rate it
2/3/2011 4:26:00 AM • HP Compaq nx7300... • Answered on Feb 03, 2011
Cant use system restore because
Hi. I provided you a link regarding shutting down issue on your computer. Please click here.
9/18/2010 8:13:29 PM • HP Compaq nx7300... • Answered on Sep 18, 2010
2answers
Where can i download hp compaq nx7300 sound
visit the link below, select your operating system (Win xp, Vista, etc), then proceed for the download.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=3310302&taskId=135&prodTypeId=321957&prodSeriesId=3310301&lang=en&cc=us
Good luck.
5/10/2010 10:06:41 AM • HP Compaq nx7300... • Answered on May 10, 2010
HP compaq nx7300. Unable to connect to the internet
if your running wireless, and it requires a WEP key, load it each time you desire to log on, online. leaving the WEP key installed would be a breech of security. if you don't have the wep key call up your isp company, and obtain it. if your company is being a d-bag with the wep key and, you need to obtain the WEP key.
by
http://www.aircrack-ng.org/
12/30/2009 12:04:31 AM • HP Compaq nx7300... • Answered on Dec 30, 2009
Driver audio
o check, click windows start button, point to computer, click manage, then look for device manager. If you see an exclamation or "x" mark on your audio device this means that your audio driver is not properly installed.
Uninstall the audio driver then re-intall it again. visit www.hp.com/support and look for your audio driver if you dont have the cd installer.
6/4/2009 1:59:25 AM • HP Compaq nx7300... • Answered on Jun 04, 2009
2answers
HP Compaq nx7300
by removing your battery you are not going to loss your data
so you can do it
but i think you should try this battery by abstract this battery first and than clean that chep by air and reconnect your battery you will find the solution
3/13/2009 5:14:09 PM • HP Compaq nx7300... • Answered on Mar 13, 2009
Enternal power supply unit for a hp compaq nx7300
The part numbers for power supplies for your PC can be found HERE. If you need further help, I’m available over the phone at https://www.6ya.com/expert/robert_33d06d08b28d1f14
3/10/2009 11:24:20 PM • HP Compaq nx7300... • Answered on Mar 10, 2009
2answers
Audio devices
hi am pop i wanna download hp sound on my laptop
2/15/2009 12:42:01 PM • HP Compaq nx7300... • Answered on Feb 15, 2009
Hello, I installed anew version
If you had a VISTA before you have to find the audio Driver's Go there and get your driver's        http://welcome.hp.com/country/us/en/support.html
1/16/2009 5:03:29 PM • HP Compaq nx7300... • Answered on Jan 16, 2009
SOUND DRIVERS
Go to website www.driveragent.comand you can get any drivers you need for your laptop
1/1/2009 12:00:35 AM • HP Compaq nx7300... • Answered on Jan 01, 2009
Internet background color is white
Check display properties and make sure color depth is set to highest.
Reset colors with IE back to defaults.
Try Firefox.
10/25/2008 7:21:10 AM • HP Compaq nx7300... • Answered on Oct 25, 2008
3answers
I need to know how to turn on a HP X13-04657 LAPTOP, all the lights are on but nothing on the screen.
HP X13-04657, is 2007 PC THOSE this PC has CCFL back lamp strip that is dead.Vista era PC, laptops. are hard to work with now, 17 years old.is this not a HP COMPAQ presario HP X13-04657 (wrong name!) sorry !became HP in 2002. so is HP but manuals are super hard to find now. that x13 is part of the microsoft license code vista. (so is distraction to what it is)the real name of the Laptop is and was Presario CQ61 laptop CQ61 the PC has bottom sticker that shows the real names of PCs.CQ61-219TU is real name of on CQ61, there area many different sub codes, and they are not all the same.CQ61-306AX this had CCFL (cold cathode florecent lamps) that love to fail 3 waysdead, blinks ,dime or yellow = white.was made until 2009 and evolved, to LED backlamps.-410 is CCFLI will answer for CCFL as those just love to fail,but the the test is so easynow the answer for ANY laptop this old. 2007 and older. black screen all the time, and BIOS screens dead, answers only me. here. remove the main battery (large) it simply snaps off the bottom.the power pack is next we run the PC on your power pack AC to DC it must make the screen glow with something, do not use the wrong pack as in mixed up with others.now the lap top seems on, even the fan blows, LED glowpoint a flash lamp at the screen ,dark' room , and of you see any kind of LCD data on the screenthe CCFL lamp below #1 is bad.this is phase 1 testing, as other things can fail too. The keyword below is Mercurythis tells me it is those pesky CCFL glow tubes. 2007 is the year some PC went to LED back lamps. yes I was correct the service manual I did find proves they made both lamp types ccfl-hp07-psnmcz4s4yabbrmds04n13cd-d-0.jpg
4/17/2024 12:37:57 PM • HP Computers &... • Answered on Apr 17, 2024
Dove posso scaricare il driver per HP ScanJet 8270? ente compatibile per windows 10...
Question edited for clarity. Question translated to English. We only speak English on this North American website. https://www.google.com/search?q=hp+scanjet+8270+driver+windows+10
HP Scanjet 8270 Document Flatbed Scanner
Hewlett-Packard https://support.hp.com > ca-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner ... drivers free of cost for Windows and Mac ... Windows 10 / ...
Hewlett-Packard https://support.hp.com > ee-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner. This is HP's official website to download the correct ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Download
Softonic https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.softonic.com Download the latest and official version of drivers for HP Scanjet 8270 Document Flatbed Scanner. This driver package is available for 32 and 64 bit PCs. It is ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Free ...
Download.it https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.download.it Download HP Scanjet 8270 Document Flatbed Scanner drivers varies-with-device. Software drivers for the 8270 flatbed model of the HP Scanjet printer. ..
4/10/2024 8:38:39 PM • HP Computers &... • Answered on Apr 10, 2024
2answers
HP 8440P Laptop. I don't remember my password. Help needed for HP 8440p.
This video shows you what to do if you forget your computer password:
4/6/2024 8:00:24 AM • HP Computers &... • Answered on Apr 06, 2024
2answers
How to do a bios recovery on a hp pavilion dv5-1004nr
This video shows you how to restore the BIOS in your computer:
4/6/2024 7:57:59 AM • HP Computers &... • Answered on Apr 06, 2024
Hp dv8 not charging battery
You can follow the steps in this video to troubleshoot your battery:
4/6/2024 7:13:37 AM • HP Computers &... • Answered on Apr 06, 2024
HP Compaq nx7300 Notebook PC Logo
22 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
audio devices
  • Computers & Internet
