20 Most Recent
Ohaus Pioneer Series Analytical Balance, 210 G X 0.1 Mg 115 VAC Questions & Answers
Balance is giving me a
The error 8.2 is pretty general. Most likely it is caused by damage to the load cell. There are some things you can try before you decide to get the balance repaired.
1. Turn the balance off and unplug it. Count to 20 and plug it back in anf turn it on.
If that does not work.
2. Put a 100g weight on the platform (the weight does not have to be exact).
3. Plug the balance in and wait for the count down. If the count down starts at 99 you can stop this procedure will not work. If the count down starts at 255 continue.
4.The balance will read error 8.2 again at the end of the count down.
5. Unplug the balance.
6. Remove the weight.
7. Plug the balance in and wait for the count down. The balance should count down and turn off.
8. Turn the balance on and it should work normally.
If this does not work the balance needs to be repaired.
Will one of the newer sensors work in place of my 1457 sensor?
It's possible that one of the newer sensors could work in place of your 1457 sensor, but it depends on the specifications of the newer sensors and the compatibility with your base unit. The I MAX1457 sensor, which is a highly integrated analog-sensor signal processor optimized for piezoresistive sensor calibration and compensation. However, I have no information about its compatibility. If you're looking for a replacement sensor, I suggest contacting the manufacturer of your base unit to inquire about compatible sensors. Alternatively, you can check the user manual of your base unit to see if it lists compatible sensors. Garage door opener sensors are not universal. Safety sensors can only communicate with garage door openers from the same brand.
How can I adjust the time on my weather station model #sgr72914?
- Access the Time Setting Mode:
- Locate the 'Set' or 'Settings' button on your weather station. This button is typically found on the front or the back of the unit.
- Press and hold the 'Set' or 'Settings' button for about 3 to 5 seconds. This action should access the time setting mode, where you can adjust the time.
- Adjust Hour and Minutes:
- Once in the time setting mode, use the 'Up' or '+' button to increase the hours and the 'Down' or '-' button to decrease the hours.
- After setting the correct hour, press the 'Set' or 'Settings' button again to move to the minutes setting.
- Use the 'Up' or '+' and 'Down' or '-' buttons to adjust the minutes accordingly.
- Confirm the Time:
- Once you have set the correct time, press the 'Set' or 'Settings' button again to confirm and exit the time setting mode.
- Check the Time Display:
- After setting the time, check the display to ensure that the time is displayed correctly.
