20 Most Recent Seagate (ST3320820U2-RK) 320 GB USB 2.0 Hard Drive Questions & Answers
2answers
Power light flashes but disc doent spin
no hablo ingles
5/25/2019 12:43:22 PM • Seagate... • Answered on May 25, 2019
Hard extrnal seagate 500 Gb drivers
Only Win98SE requires driver. Windows XP, Vista, 7 or 8 - no drivers required
8/23/2014 11:40:41 AM • Seagate... • Answered on Aug 23, 2014
ST3320820u2-rk hard drive powers up
Do an update from the manufacture of your computer, could be just a driver issue, Or that is USB2.
5/6/2014 10:42:49 PM • Seagate... • Answered on May 06, 2014
Seagate st3320820u2-rk drivers
rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions they will automatically search for and find the correct driver also at cnet http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: motherboard name sound drivers you might have to try a few times to get it right
http://download.cnet.com/drivermax/3000-18513_4-10572602.html
Windows 2000/XP/Vista/7/8 free driver program
http://download.cnet.com/drivers-for-free/3000-18512_4-75548155.html
Windows XP/2003/Vista/Server 2008/7/8 free drivers
http://www.downloadcollection.com/device_doctor.htm
Device Doctor is a freeware Windows application that scans your computer hardware and checks to see if there are new driver updates available for your devices. It also locates drivers for Unidentified Devices in the Windows Device Manager. This tool was designed to be very simple and easy to use
http://www.innovative-sol.com/drivermax/ free program, paid update available
hope this helps
8/20/2012 9:18:08 PM • Seagate... • Answered on Aug 20, 2012
Seagate (ST3320820U2-RK) 320 GB USB 2.0 Hard Drive troubleshooting
The problem may be there in your hard drive, try the hard drive with another computer and if the problem persists, go to the nearest Service Center of the Manufacturer.Hope this helps, Mrityunjay.
6/21/2012 12:42:05 AM • Seagate... • Answered on Jun 21, 2012
Hard disk drive is not
  1. check the usb ports is enabled or not..
  2. and check your system security...
  3. if both is correct definetly it shows..
  4. go to device manager and check it the universal ports are active or not..
  5. if everything is fine then it also not show it means connect other no.of ports....
  6. and if any seagate instaliing cd installing is having means first do that one...
  7. Thank you..
1/1/2011 11:55:00 AM • Seagate... • Answered on Jan 01, 2011
ST300003U2 hard drive powers up ok, power light
Try to plug it in to another PC to see if you get the same message. See if you can run a scan disk on it from Windows to see if it's bad or going bad too.
To be honest, device not recognised is a bad sign. :(
12/22/2010 2:12:26 AM • Seagate... • Answered on Dec 22, 2010
Seagate 320 GB external drive stopped functioning
If it is listed in the many serial numbers on seagate website you can get it fixed under warranty, Info might be lost though. If it is just a power issue then that is what they will replace call first to get a solution.
9/3/2010 3:49:00 PM • Seagate... • Answered on Sep 03, 2010
I can not add any folders or delete anything off of my free agent
if this is a emoty drive formatit by rigth clicking on it in mycomputer
6/4/2010 1:34:09 AM • Seagate... • Answered on Jun 04, 2010
Disco duro externo
Seagate disco duro externo
si estás usando un cable USB la computadora deberia encontrarlo automaticamente, el programa es solo para proporcionarte utilidades.
si quieres recuperar estas funciones puedes bajar varios de estos en el siguiente enlace:
http://www.seagate.com:80/www/es-la/support/
busca tu modelo y baja el programa recomendado de hecho esos los puedes usar el mismo programa para varios modelos
si te sirve la ayuda no olvides darme un rating
gracias
4/28/2010 2:19:54 AM • Seagate... • Answered on Apr 28, 2010
How to delete backup on my seagate backup plus slim
Detailed steps to manage backup disk space
To delete old backups on Windows 7/8/10 using AOMEI Backupper, you need to set up Backup Scheme during the process of creating a backup. When your backup versions exceed the number of backup images files, AOMEI Backupper will delete older backup automatically. Step 1: Connect your Seagate Backup Plus drive or Central hard drive to the computer and make sure it can be detected by your computer. Step 2: Download AOMEI Backupper Professional, install and launch it. Step 3: Click Backup and File Backup subsequently Step 4: Choose the files and folders you want to backup and pitch on a path for it. Then, Click Schedule option and select Schedule Settingsfrom the following window. Step 5: Click Scheme option, tick Enable Disk Space Management and select whatever Scheme you need from the drop-down menu. Then, back to the main page of File Backup and click Start Backup. After that, your older backup will be deleted automatically when your file backups exceed the versions of backup image files.
2/26/2024 7:21:41 AM • Seagate... • Answered on Feb 26, 2024
Ive got a 8tb seagate its got a blinking blue light and wont connect to my Pc? Any help?
Did you initialize it?
7/3/2023 8:38:03 AM • Seagate... • Answered on Jul 03, 2023
Seagate Portable Hard drive 4TB, part number 2N1AP6-500
Hi, Please put your computer into safe mode before attempting to connect to the hard drive again. Safe mode turns some feature off when activated so whatever program is forcing the shutdown might have be paused when connecting to the external hard drive. Also, try connecting the hard drive to a non-laptop intermediary device and then connecting that device to your computer and attempting to access the hard drive folder within the intermediary drive. Thank you.
11/11/2022 2:11:28 AM • Seagate... • Answered on Nov 11, 2022
2answers
How to recover data from a dead Seagate external hard drive on my Computer?
Should be careful with the data file deposited on the Seagate external hard drive. your Seagate external hard drive might be dead or corrupted. In this situation, you might need to rely on data recovery software to get back data and files on the dead Seagate external hard drive. So you can rely on data recovery software to get back lost data and files when the Seagate external hard drive is dead and inaccessible. Data recovery hong kong technician provide the Ontrack EasyRecovery data recovery services are able to recover data and files from accidentally formatting, corruption, virus attack, dead, system crash under different situations Seagate external hard drive on Windows Computer. This data recovery software allows you to deep scan the dead Seagate external hard drive so as to find out almost all lost files with original quality in a short time. You can also rely on this software to recover files from dead/damaged Seagate external hard drive. The software supports to get more recover: Seagate External hard drive, data file, documents, PDF, Excel, photos, music, and videos any HFS, HFS, FAT, ExFAT, and NTFS format based data and file and more. It will recover data and file from all external storage devices that can be recognized by your Windows PC Computer/Laptop. Hope this helps you get to recover all your lost data and files from your dead Seagate External hard drive.
10/8/2021 1:02:33 PM • Seagate... • Answered on Oct 08, 2021
What enclosure is compatible with a Seagate Barracuda 7200.7 SATA Drive?
TRY LOOKING FOR TIGERDIRECT .COM THEY SELL STUFF FOR COMPUTERS
10/3/2021 8:21:41 PM • Seagate... • Answered on Oct 03, 2021
5answers
Need restore my RAW file system back to NTFS without losing any hard drive files?
There are two options for you to get your drive stuffs back right now: 1). Do not format this RAW file system external hard drive temporarily and plunge it to your PC. And then, choose and apply RAW external hard drive data recovery software to scan this drive and find your preferred drive files back as many as possible. 2). Directly consult some professional data recovery services from some data recovery companies or agencies. In the future, remember to save copies of everything important on at least two devices in case of any similar data loss issues.
1/5/2021 2:43:04 PM • Seagate... • Answered on Jan 05, 2021
I have seagate plugged in and attached to my computer. I downloaded the program but I get the message connect a dashboard enhanced drive to activate features ??
Can you please provide more detail on the program you are downloading, the model of drive, and model of computer?On the face of it, the program seems to be saying it is not compatible with the model of drive you have plugged in, or that the drive has been reformatted in a way that is not compatible. Does the drive show up in the File Explorer / Finder of the machine?after comment : ok, if you can drag and drop files onto it, then That means it is operational, and recognized by the system. The next question is why you can’t install the Seagate Desktop software. Where did you get the software from? Try going to Seagate Support and looking up your drive model, and doing a fresh download of the software they have for that model. Alternatively, there are other backup software packages available, Acronis, Aoemi, EaseUS, and others. You can find reliable downloads of utility software at downloads.com (CNET) or look for reviews from PcWorld or PCMagazine for their recommendations of the best paid and free backup software
10/20/2019 9:49:12 PM • Seagate... • Answered on Oct 20, 2019
Necesito controlador para Seagate medalist 4310
I need controller for (English please) in a computer,. or DVR or what, where does this HDD go? Medalist 4310 (ST34310A) built in 1999 (20 years old ) why use any drive this old. why? it's useless. my wild guess, is this you have a PC and ustated PC has SATA only ports (modern) and this old old HDD is PATA drive, with ribbon cable wide. and you think it can run on modern PC. well they do sell cards (PCI-e) that fit and work. 4.31GB is the size , holds about 1 top movie . are you going to boot from this drive, if yes, very complex answer I will skip here. (ask maker of card , if it can) newegg.com has them all, any thing you can dream of , is there. if you look. https://www.newegg.com/Product/Product.aspx?Item=9SIA4UB8ZU9127&Description=pci-e%2c%20pata%20IDE%20card&cm_re=pci-e%2c_pata_IDE_card-_-17Z-0007-00AF2-_-Product again, no PC stated, no OS stated. nor of booting is needed to the PATA relic drive. from 1999.
4/8/2019 1:42:01 PM • Seagate... • Answered on Apr 08, 2019
4answers
Hi, I accidentally dropped my 2 tb Seagate expansion disc and now its making funny noises andm it wont even read on my windows 8 computer. Can some 1 help me please?
unfortunately it appears that the internals are shot if the funny noise is a clicking sound or squeal then the repair is a new hd unit as they are generally not repairable.
3/27/2019 9:36:59 AM • Seagate... • Answered on Mar 27, 2019
Seagate (ST3320820U2-RK) 320 GB USB 2.0 Hard Drive Logo
15 questions posted
Top Seagate Computers & Internet Experts
Sean Wright
Sean Wright
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Seagate Computers & Internet
Most Popular Question
power light flashes but disc doent spin
  • Computers & Internet
