20 Most Recent
Insignia NS-DV2G MP3 Player Questions & Answers
Need Speakers
Bluetooth speakers are no less than any other popular gadgets and they are gaining in success rapidly. These wireless devices are the perfect match between you and your favourite music. Connect this with your smart phone and see how it fills your life with tune. Bluetooth speakers usually come in all shape and size, from potable to wireless and works elegantly keeping that same compatibility and gets connected with almost all kind of phones, whether it's a windows phone or an android and lets you enjoy better music than in-built speaker. PTron Bluetooth speakers will have good bass sound.
MOST POPULAR BLUETOOTH SPEAKERS OF 2016 IJ Tech
Won't play .avi files
get handbreak to convert the video into a supported format ( check the manual for your phone / to see what formats are supported and then convert the video into that format type )
hand break
I bought a refurbished insignia
Hi
Flip the MP3 player's "Hold" switch to "Off" if the switch is on. Depending on the MP3 player you own, this switch is likely located at the side or top of the player. Once the switch is off, try to turn the player on.
Let the battery of the MP3 player die. A frozen MP3 player is technically still running, and thus the battery for that player is being drained. Wait until the battery is fully dead before you can unfreeze it
Charge the MP3 player using either a computer (that's turned on) or an electronic MP3 charger. Charging the player's battery may "jolt" the player out of its frozen state. Connect the player to the computer or charger via the player's USB cable. Charge the player for 30 minutes before attempting to turn it on.
Sync the player with the appropriate software program (for example, Windows Media Player) for the MP3 player. Connect the player to the computer as described in the previous step. Open the software program and click the "Sync" tab at the top or side of the program. If necessary, click "Start Sync" underneath the tab. The name of the player appears under the "Sync" tab if the player has synced successfully. Try turning the player on once it has synced with the program.
Press the small "Reset" button on the MP3 player. This hard reset shuts the player down completely. Use a pin, tack or thin nail to press down the very small "Reset" button on the side or back of the MP3 player to reset the player. Then, try to turn the player on.
My Insignia Sport Player MP3 says all music is Unknown?
I have the same problem with my RCA it occurs every so often. What I do is delete everything on there by useing he software that came with it and then change the mode from from MTP to MSC and back that way It formats it so Windows Media player( WMP) can see that it is really empty. Then I end the sync with the WMP and start a new sync. after that all I have to do is load the songs back on. This might not work for you since you have a different MP3, but if there is orginal software that came with it use that to delete. If you dont have any orginal software then you can still try to end the sync with WMP and see if that works.
hope this helps
Database full ns-2v17b
Your database is corrupt
You have two choices here:
1) Delete the songs
2) Reformat the player
The player isn't trying to BS you
There are two ways to format an Mp3 player - one on the computer
itself, and one in Windows Media Player. Both methods will end up
erasing all the songs on the player, but the player will be "good as
new" after that. Sometimes reformatting in this manner will override
the player's native formatting and cause problems - this can be
reversed in most cases by updating the player's firmware. Firmware
upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or
FAT32. - Connect player to computer, double-click my computer, right
click on icon of mp3 player and select format. This only applies to
Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media
Player. Click on the Sync tab. Pull down the drop down menu underneath
the Sync tab by moving your cursor over the Sync tab and left clicking
on the little black arrow underneath the Sync tab. Highlight "name of
Mp3 player here 1GB" (wording may vary slightly), and then select
"Format." - this should erase everything.
-Tha Mp3 Doctor
I am electronicly challenged...I don't know if
MP3 players can only play music files in mp3 file format.
You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player.
For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.
Click on this link for instruction on converting musicfiles to mp3 file format :-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
How do i delete recordings?
Hi karens1016...
Deleting Files,Pictures,Videos,Audio
Books, Apps,etc. from MP3 Player/Ipod
BIG WARNING: DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
ONE MORE BIG WARNING: BE CAREFUL AND DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
This is a FREE answer, Please take time to rate me
Computers do not sense the
It sounds like you need drivers for this device to work on your computer's .
You should try Driversguide.com or drivershq.com..Or goto Insignia's website and get software from them..
Hope this helps
