20 Most Recent
Datamax DMX-I-4212 Label Printer Questions & Answers
Top of form error! help
Hold in the Feed button for 4-5 seconds, which causes the printer to attempt to "Auto-calibrate." If that doesn't solve it, then slide out the Media Sensor (green plastic bar that sticks out over the labels) about 1 inch from all the way in ("in" = left if looking from front). Then press Feed to clear errors. If still get same error, then look for piece of label or ribbon stuck in that error - ok to blow out with canned air. Then try holding in Feed again for 4-5 seconds to Auto-calibrate again.
4/29/2014 6:45:06 AM •
Datamax...
Answered
on Apr 29, 2014
Supplies
4/29/2014 6:00:48 AM •
Datamax...
Answered
on Apr 29, 2014
Keep getting a check supply error
Slide out the Media Sensor (green plastic bar that sticks out over the labels) about 1 inch from all the way in ("in" = left if looking from front). Then press Feed to clear errors. If still get same error, then look for piece of label or ribbon stuck in that error - ok to blow out with canned air.
4/29/2014 5:22:55 AM •
Datamax...
Answered
on Apr 29, 2014
I have a Datamax DMX I-4212 Barcode Printer.
Welcome to FixYa.It shows that the printer is not communicating properly with the computer.Solution:Uninstall the current printer driver from the control panel then re-install it.Your printer should came with a cd (software/driver/installer), use it to re-install the driver.Thak you for using FixYa.
12/27/2011 1:34:57 PM •
Datamax...
Answered
on Dec 27, 2011
The printer can not print at all.But every thing
It's a thermal printer, the printer therefore needs to get hot to heat the paper and in turn print the document. The paper changes form due to heat.
Check that your printer is getting hot. Also try a newer roll of paper.
If the paper feeds through and it gets cut off, then the heater needs to be repaired/replaced.
Claim warranty support if you can.
Take care!
damnor01
5/19/2011 6:39:17 PM •
Datamax...
Answered
on May 19, 2011
