20 Most Recent Emerson EWL2005 20 in. LCD Television Questions & Answers
Picture too small on screen
It's a fairly inexpensive repair but with the low cost of new TVs I recommend junking It.
1/16/2018 5:42:19 AM • Emerson EWL2005... • Answered on Jan 16, 2018
We have an Emerson 20inch tv that suddenly lost it's color.
Do a reset to this TV and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
5/26/2017 2:40:45 PM • Emerson EWL2005... • Answered on May 26, 2017
0answers
Unit wont power on, no
Recheck the power source like the power outlet output?Yes,tries tv unplug,replug it back like about an hour later for the tv to do a resetting to factory setting.If tv still have same problems,no power to the set.Than the tv power supply board it the cause and the problems,that the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
7/30/2011 10:29:14 PM • Emerson EWL2005... • Answered on Jul 30, 2011
0answers
4answers
The tv's captioning won't work, even though it
Have you tried CC2?
9/24/2010 1:24:00 PM • Emerson EWL2005... • Answered on Sep 24, 2010
3answers
Red indicator lite only comes on for a second when
That is not a DIY problem this problem requires a technical knowledge to fix it.It is more technical.I would suggest to bring your TV to a repair shop. thank you!
9/11/2010 2:18:44 AM • Emerson EWL2005... • Answered on Sep 11, 2010
Where can i get a manual to help me program a LCD
<a href="http://tv.manualsonline.com/manuals/mfg/emerson/ewl20s5.html">http://tv.manualsonline.com/manuals/mfg/emerson/ewl20s5.html</a><br /> <br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><a href="http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide">http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> </span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-bidi-font-size: 12.0pt; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span>
8/25/2010 12:21:52 AM • Emerson EWL2005... • Answered on Aug 25, 2010
My Notebook doesn't recignize my hdmiflatscreen tv
Right, well, IF your TV has a DB15 Female Plug on it then you CAN, connect it up and it will work, as a second "Monitor". OR If the laptop, has a "Composite Video" a Yellow RCA socket, then you can, connect to the TV's Composite IN. & it will be a second monitor. Otherwise you cannot, the VGA signal is NOT compatible with a TV's input. SOME cards have a connector that plugs into the DB15 and to the TV, but they are "Special". In saying that though you can "Micky Mouse" things together and get an output, but it real poor quality, and disappointing results, there are various posts on the net about doing this if you wish.
Remember DRIVERS, you also need the drivers installed & setup correctly in order for the hardware to work. As a tip, When connecting to a TV, always connect like this......First, plug all cables into TV's correct Video input(s). Connect up the Sound, plug all cables into laptop, turn TV ON. NOW, start the laptop, you should now soon see the an image.
NOTE: Some laptops & other devices, have HDMI out, sometimes, the AUDIO is not passed through, the HDMI cable, & the Audio must be run from Audio/Line OUT on laptop to AV IN on TV.Also some laptops have a socket that a multi-way 4/5/6/7 pins. A connector plugs into this, you then can connect to these connections, as you would normally. At the rear or side of the PC there should be either or both of a 15 Pin DIN Plug, HDMI socket. or a Yellow RCA or 4 -7 pin DIN. Now IF these are present then YES you can connect to a TV. Now some TV's have a connector a DB15 MALE, so that the cable from the PC to the TV, is DB15. this plugs in directly, with appropriate DB15 cable. This, however, will ONLY take the VIDEO to the TV, Audio is delivered via the "Audio Out" Jack on PC, and Plugged into the AV Sockets on the TV, with a dual cored coaxial cable, they are Red & White. Some PC's also have a Yellow RCA Connector, OR a 4 -7 Pin DIN Socket, that requires a Special Adapter Cable (That generally came with the unit, and are colored and marked as to output) to use, for Video/Audio Out to TV. This signal is Composite or SVHS Video & Stereo Out. This connects up TO the TV's Composite/SVHS input Jacks and the Red & White Audio IN, RCA Jacks, &/or DIN SVHS socket.
First you need to know if your PC can output to a TV. Then you need to get the adapter & cables that connect the PC to the TV. Then you need the correct TV drivers installed for your video card. When they are all installed, you need to "Enable" that Monitors, the TV's, Desktop. You need to set either a "Cloned" display or "Spanned, Extended Desktop". Go to "Display Settings" Now ensure the TV/Monitor connected has the correct input/output display settings. Adjust the screens resolution via the resoloution "Slider", it is best to start with, 800x600 32 bit color. or even lower. and once working OK, THEN increase to max resolution, your TV can handle, find out from manual. Once it is all connected up. It should all just work great. Now, from then on, &, to get it to work every-time, the process is. Turn everything OFF. Connect the leads between PC & TV, Turn the TV, ON. Then, startup the PC up. It should "Detect" that it has TWO "Monitors" ie: One Monitor & One TV/Monitor, & you should see your desktop appear after a bit. Now you have screen 1 & screens 2. Now, if you are using "Cloned" mode, then whatever is displayed on the Master monitor, will be displayed on the TV. If you used Spanned, mode, in this mode, however, you will have to."Drag" the Video window, over to the TV, and it is though, you have one "Big Desktop". Now IF using Nvidia or ATI then BOTH of those have thier OWN, Control Panel, this, all then can make it all a lot easier to do it. So I would suggest that this method be used. But if you get stuck, or just want to do it by hand, then the the "By Hand" method is the only way.There is a great program called MultiMon, this allows great control over dual displays, and is well worth installing.
3/7/2010 2:11:44 AM • Emerson EWL2005... • Answered on Mar 07, 2010
Captions won't turn off
Is it hooked up to a Motorola cable box? If so go to the menu button on the box and navigate menu to the Closed Caption menu. The box can override the TV settings.
1/7/2010 1:10:27 AM • Emerson EWL2005... • Answered on Jan 07, 2010
I need to find wall mounting equipment for this TV
look on ebay the might have the right wall mounting for your flat screen tv
benner
lig,pa
11/20/2009 10:04:11 PM • Emerson EWL2005... • Answered on Nov 20, 2009
When you shut tv off and try to turn back on it
go into menu and select caption button,skoll though menu till you come to text1 or to then selct off to turn caption off this security problem will come on when the tv loses power.
6/12/2009 10:56:45 PM • Emerson EWL2005... • Answered on Jun 12, 2009
How do you hook up a Emerson EWL20S5B LCD TV with a PS3?
Why don't **** your own **** you **********.
4/18/2009 12:04:33 AM • Emerson EWL2005... • Answered on Apr 18, 2009
2 year warranty
the Majority of problems on this and all other LCD TV's are capacitor problems the power pack needs smooth power to work correctly however the warranty should be valid and you need the proof that you bought it and you need to know who to contact about the 2 year warranty it may be Emerson you need to speak with not Walmart. I would contact them next(Emerson), or whom ever the third party repair service is that will cover the Warranty.
hope this helps
4/7/2009 7:06:39 PM • Emerson EWL2005... • Answered on Apr 07, 2009
I turn on the set and in about 30 seconds it shuts
dont unplug the switch panel, the capacitors on the power pack are most likely blown they need to be replaced this will require soldering skills or take it to a tv service center.
4/7/2009 7:02:13 PM • Emerson EWL2005... • Answered on Apr 07, 2009
Cannot get to the channels to play games with unversal remote
use the input button
4/7/2009 7:01:13 PM • Emerson EWL2005... • Answered on Apr 07, 2009
Emerson lcd tv problem setting universal remote
try funai and sylvania
4/7/2009 7:00:48 PM • Emerson EWL2005... • Answered on Apr 07, 2009
I have a lcd tv
I have a Emerson LCD TV that I can't program into my ramote control. Can you help me?
1/14/2009 9:24:05 PM • Emerson EWL2005... • Answered on Jan 14, 2009
2answers
20" digital flat stero tv moel CR202EM8
It sounds magnetised. Is there a magnet near that side... like a speaker?
It probably needs degaussed. Many TV shops have a device that does this, at a cost to you. Also, the set degauses itself for about a second when it's first turned on after being off for a while. So it may go away by itself eventually.
Hope that helps...
Geno
12/15/2008 4:21:56 AM • Emerson EWL2005... • Answered on Dec 15, 2008
How to setup a onn remote control to a emerson TV
1. Turn on your Emerson TV. 2. Consult the ONN remote manual for Emerson TV codes. 3. Press TV on the ONN remote. 4. Enter the correct code. 5. Test remote functions. - If unsuccessful, try code search or auto-programming. 6. Ensure compatibility.
1/8/2024 3:58:07 PM • Emerson... • Answered on Jan 08, 2024
Emerson EWL2005 20 in. LCD Television Logo
Popular Tags
32 questions posted
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Emerson Televison & Video
Most Popular Question
red indicator lite only comes second
  • Televison & Video
