20 Most Recent
Polaroid PLA-5048 50 in. HDTV Plasma Television Questions & Answers
REMOVEABLE STAND
Good luck with finding one. Each TV manufacturer has a unique mounting system for the stand. Unless you go directly to Polaroid, you will have a very hard time finding one. Might check Ebay also.
4/18/2014 4:00:24 PM •
Polaroid...
Answered
on Apr 18, 2014
Picture too large
Find the "wide mode" or "zoom" button on your remote or something similar.
11/17/2008 4:56:45 AM •
Polaroid...
Answered
on Nov 17, 2008
Polaroid TV working with constant red flashing light
If your Polaroid Roku TV is working fine but the red light is continuously flashing, it could indicate an issue that may need attention. Here are some steps you can try to troubleshoot the problem:
- Power Cycle:
- Turn off the TV and unplug it from the power source.
- Wait for at least 5 minutes.
- Plug the TV back in and turn it on.
- Check Remote Control:
- Ensure that there are no stuck buttons on the remote control. Press each button to make sure they are not stuck in the pressed position.
- Update Firmware:
- Check if there is a firmware update available for your TV. You can usually find this information in the TV's settings menu.
- Reset to Factory Settings:
- Perform a factory reset on your TV. This will erase your settings, so be sure to back up any important information first.
- Check for Physical Obstructions:
- Make sure there are no physical obstructions around the TV, particularly around the infrared sensor on the TV and the remote control.
- Contact Customer Support:
- If the issue persists and your TV is still under warranty, consider contacting Polaroid customer support for assistance. They may be able to provide additional troubleshooting steps or offer a solution.
- Professional Repair:
- If the TV is no longer under warranty and the issue persists, it might be advisable to consult a professional technician or a TV repair service to diagnose and fix the problem.
Always refer to your TV's user manual for specific instructions related to your model. If none of the above steps resolve the issue, it's recommended to seek assistance from the manufacturer or a qualified technician for further diagnosis and repair.
12/27/2023 10:15:57 PM •
Polaroid...
Answered
on Dec 27, 2023
How do I switch my Polaroid P40LED13 TV on to AV mode. No option in sources
If you are using the standard SNES cables with the round red, white and yellow 'Jack' plug connectors they are referred to as "Component" connections. On your remote there should be a button marked "COMP". It will probably be near the top of the remote near the Power button. This should switch the TV to the channel you need.
3/27/2023 9:22:04 PM •
Polaroid...
Answered
on Mar 27, 2023
Polaroid pdx-0758 dvd player displays "open" even though thelid is properly closed, and it will not play
If your Polaroid PDX-0758 DVD player is displaying "open" even though the lid is properly closed, there are a few potential solutions you can try:
- Check for obstructions: Make sure that there are no objects blocking the DVD tray or preventing it from closing all the way. Even small objects like dust or debris can interfere with the DVD player's operation.
- Reset the DVD player: Try unplugging the DVD player from the power outlet and waiting a few minutes before plugging it back in. This can sometimes reset the player and clear any errors that might be causing the "open" message to appear.
- Clean the DVD player: Use a soft, dry cloth to clean the DVD player and remove any dust or debris that might be interfering with the player's operation.
- Try a different disc: Sometimes, a specific disc might cause the "open" message to appear. Try playing a different DVD to see if the player operates normally.
If none of these solutions work, there could be a more serious issue with the DVD player's hardware or firmware. In this case, you may need to contact Polaroid customer support or a certified repair technician for further assistance.
3/15/2023 8:15:20 PM •
Polaroid...
Answered
on Mar 15, 2023
