20 Most Recent
Polaroid FLM-1911 19 in. LCD Television Questions & Answers
Channel search: skips chanels
If you have a cable box connected, it's synch circuits are bad. If your TV has a selection for HRC/ IRC make sure you know which one cable company is using .
4/15/2017 4:16:50 AM •
Polaroid...
Answered
on Apr 15, 2017
Screen going out is this a standard issue with these televisions just wondering picture went out and it wasn't bumped or moved at all. just wondering thanks
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board....
5/9/2016 1:30:32 AM •
Polaroid...
Answered
on May 09, 2016
I am getting a white screen (no picture) on a polaroid LCD
People any lcd tv with a white screen cause by the T-con board if you have some experiences you can check with a multimeter the (smd) fuse on the T-con board it is right in de middel on top in the back of the tv. you might have to move some of the boards to get to it. if the fuse is broken replace it with another smd fuse otherwise relace the t-con.
11/1/2011 9:45:56 PM •
Polaroid...
Answered
on Nov 01, 2011
How much is a power supply
HI
The power source of your Poloriod FLM 1911 is
100 to 240 VAC in, auto selector. you can feed the TV between these said voltage levels.
Frequency is 50 to 60Hz and power concumtion is 50W.
OK.
7/13/2011 6:29:26 AM •
Polaroid...
Answered
on Jul 13, 2011
How can I chnge the input from TV-Cable to VGA? I
VGA option will be enable when tv sense video signal in that input.
Plug VGA cable in tv and hook it to video source like iPod etc then go to Menu and select VGA input.
Hope this info will help you.
Thanks.
7/30/2010 8:10:45 PM •
Polaroid...
Answered
on Jul 30, 2010
Polaroid FLM-1911 LCD TV - I got blank screen when I turn on it.
I had the same problem and got a TV repair man to fix it for real cheap. The whole fixing took less then 30 min and he goes to your house to fix the TV. He fixed it for an excellent price that left us astonished. He lives in NY. Email me if anyone needs his contact information. You wont be disappointed.
6/10/2010 3:22:15 PM •
Polaroid...
Answered
on Jun 10, 2010
Turn on tv get a white screen and no sound.
6/10/2010 3:15:02 PM •
Polaroid...
Answered
on Jun 10, 2010
SOUND WORKS GREAT, PICTURE SWITCHES OFF ALMOST
Ur LCD inverter board is dead.Replaced this LCD inverter board will get ur picture back.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.This a long board inside ur tv.
4/8/2010 3:48:16 PM •
Polaroid...
Answered
on Apr 08, 2010
Auto Channel Search places all channels in Skip
check the agc line from the tuner is functioning properly, if the agc signal , is not reaching the processor it will register that channel as being inactive and lock it out, there is not much circuit to contend with so a multimeter should do the trick to trace down the fault, you should find AGC marked on the board where the tuner modual is mounted.. i suggest obtaining a service manual to do the job good luck
1/28/2010 4:48:43 PM •
Polaroid...
Answered
on Jan 28, 2010
