20 Most Recent Ricoh Aficio SP C811DN Laser Printer Questions & Answers
Ricoh SP C811DN error sc549
unplug printer, wait minute, plug in, should reset.
check Ricoh website to trouble shoot if does not reset.
10/9/2019 8:58:49 AM • Ricoh Aficio SP... • Answered on Oct 09, 2019
How do I factory reset my Ricoh Aficio SP C811DN?
Go into SP mode. Saw it there once when I was just fooling around in SP modes at work. Enter SP mode with pressing the yellow clear all button, then 107 and holding down the red stop button. .
5/9/2017 7:21:52 PM • Ricoh Aficio SP... • Answered on May 09, 2017
3answers
Error Code SC580 on Ricoh Aficio SP C811DN
First try switching off and on the printer to reset the error.
If still there the error check the following;
  1. Check CN983, it may be disconnected on the IH inverter.
  2. Defective IH inverter - replace IH inverter.
  3. Defective IH coil unit - replace IH coil unit.
It is a bit complicated to repair these parts.
Better to contact an engineer.
Goodluck and please rate me, thanks.
4/10/2017 7:26:02 AM • Ricoh Aficio SP... • Answered on Apr 10, 2017
Error 863-06
format the drive from the machines system and restart. if this does not work call 0243494871 for the part or any other ricoh technician for help. thanks and all the best
8/2/2016 2:40:20 PM • Ricoh Aficio SP... • Answered on Aug 02, 2016
How do i fix the error message set pcu correctly on my ricoh aficio sp c811dn
Turn the machine off. Open the access door and remove the cyan photoconductor unit. Check the contact pins are straight and undamaged. Gently reinsert the unit. Turn the power back on. If the machine still does not recognise the pcu is inserted it is probably damaged and needs replacing. How many copies/prints has your machine done?
11/6/2015 7:40:48 AM • Ricoh Aficio SP... • Answered on Nov 06, 2015
2answers
My ricoh sp c811dn suddenly started displaying the
Here is a way to reset but make sure you follow the instructions correctly. turn off machine press online and escape buttons together whilst turning on machine, when display comes up wait till three options are listed, use arrow button down to select engine, use arrow right to select mode(5.mode) and ok, left arrow to 5.810 SC RESET. OK. PRESS OK AGAIN AND THEN EXECUTE AT BOTTOM OF SCREEN. Turn off printer and wait ten secs then turn back on. If only temp error this should reset and start up again, Good luck
7/8/2015 4:21:47 PM • Ricoh Aficio SP... • Answered on Jul 08, 2015
Printing black streaks
drum blade bad replace it or drum unit
4/6/2015 5:23:44 PM • Ricoh Aficio SP... • Answered on Apr 06, 2015
How do i change my ricoh aficio sp c811dn to english language?
push Menu button, then push down arrow to panel 4/4. The last option is "Language". Click OK, then you will see a list of languages with English at top. Select English and click OK
1/21/2015 8:42:00 PM • Ricoh Aficio SP... • Answered on Jan 21, 2015
Colour out of alignment on aficio c811dn ricoh.when i print a demo page,the colours are out of alignment.
The transfer belt is not calibrated or the ID sensors are dirty. Read the user manual on how to calibrate it. No manual? Go to ricoh-usa.com
11/23/2014 8:05:16 PM • Ricoh Aficio SP... • Answered on Nov 23, 2014
Service manual
go on line to the manufacturer and look up your model and down load the service manual
7/3/2014 10:05:56 AM • Ricoh Aficio SP... • Answered on Jul 03, 2014
0answers
0answers
Ricoh SP C811DN has a sc 400 error code
open the front door and left door, take out the drum unit after releasing the lock lever if look at the opening from the right you can see a black sensor unit facing inward towards drum clean its inner side with a dry cloth and put back everything it is the id sensor, machine should work now
4/4/2014 4:54:17 AM • Ricoh Aficio SP... • Answered on Apr 04, 2014
Error sc549
fuser encoder error -replace Encoder Ferrite core switch - B2234240 -replace Photo interuppter - Horizontal 7mm AW020190
3/3/2014 6:31:23 PM • Ricoh Aficio SP... • Answered on Mar 03, 2014
0answers
Permanently the SPC811DN shows SC 491
slide the pcu out - clean around it and clean the contacts inside then put back in - i
10/22/2013 11:07:31 PM • Ricoh Aficio SP... • Answered on Oct 22, 2013
Ricoh Aficio SP C811DN Laser Printer Logo
72 questions posted
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Aficio Ricoh
  • Aficio Ricoh
Most Popular Question
fix error message set pcu correctly
  • Office Equipment & Supplies
