20 Most Recent
RCA L32WD12 32 in. LCD HDTV Questions & Answers
I was given an rca hdtv model L32wd12 by my
I am not an expert but I would guess the tv is broken.
The set might need retuning to receive programmes from an aerial but that would necessitate using the remote to select the main menu. If the menu cannot be selected it is a big clue...
When a signal is injected through an HDMI port or similar the tv should respond automatically. If it doesn't respond I believe that is another clue the tv is broken.
You could make sure by downloading an instruction manual just to be certain you are doing everything right.
RCA TV LCD - 32" video and sound trouble
Fault at its main digital board.
Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Rca tv model l32wd12 ser #c342cj0a2. When you turn on green light will flash on and off and screen will flash. No picture or sound.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "
brand name" to your device, in the "
Search box at the top right of the display window of the Homepage" to get gathered related posts.
Well i have a new
Hi ,
Power on the unit in the dark room then shine with the flashlight directly in
the screen, you will barely see the images. This is because your backlight is
not functioning. The following reason is the caused.
1. Power supply - missing B+(supply voltage) coming from this board feeding the inverter board. This is caused by
faulty transistor, dried/leaky electrolytic capacitor, open fusible resistor.
2. Inverter board - even
the B+ is good from the power supply, if the fuse, driver transistor, driver
transformer is faulty no output to the backlight resulting to black picture.
3. Busted backlight - even
inverter board is good but if this is busted resulting to black picture also.
Diagnosing the fault is technical and if you don't have necessary tools and test instrument and can't fix it yourself, I would
advice you to look for an experienced
technician to isolate the
problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Why does my tv take a few times of coming on and off to stay on?
Main power supply regulator section fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
How do i fix my rca
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Why is my tv turning on and off?
A common problem with that type of television is bad capacitors. Carefully remove the back of the set with the tv laying face down and with power OFF. Then look for the board that the AC power cable plugs into that it the power supply. There are many capacitors on that board and people usually say they look like batteries standing up. They usually are black. They all should have flat tops, if you see some that are bulging or puffed up then they are bad. You can change these yourself with a soldering iron or take to a shop and have someone do this for you.
T v comes on then goes off
If it comes on 'by itself' that's another issue (one which I'm currently working on), but if you're turning on the set and it shuts down, then first is the most common problem, capacitors on Power side. If willing and have the meters to check (capacitor w/ESR meter), then there's opportunity to repair. Start with the largest uf (typically the one) and work down from there. If good, I go towards the Thermistor next. If you're not the slightest knowledge about what kind of power is in those circuit boards. Do not attempt any repairs. If you're lucky enough not to hurt yourself, you'll burn out more 'good' components in there.
I have a RCA L32wd12YX7
You have to press AND HOLD the power button for several seconds to turn this type of TV on.
