20 Most Recent Amana ACM1580 Convection Microwave Oven Questions & Answers
0answers
Light burned out
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms (light burned out) and let us know which light it was.
3/18/2015 5:35:54 PM • Amana ACM1580... • Answered on Mar 18, 2015
Amana microwave
Remove the cover from the microwave. Where the door latches are you will find a couple small black switches. The buttons on the switches will be depressed when the door is closed. Check the switches to see if any are burned up or broken. They should have somewhat of a snap feeling when depressed with your fingers. If one is bad the machine will not heat. Replace the switch.
3/23/2014 11:35:20 PM • Amana ACM1580... • Answered on Mar 23, 2014
AMANA ACM1580AW WNONT HEAT
If the inside light, cooling fan, and turntable are not all coming on when you hit "Start" to cook, then you likely have a bad top or bottom door switch, or that switch's mount is loose, misaligned, or broken. See these help files: http://031d26d.namesecurehost.com/mwd/safety.txt http://031d26d.namesecurehost.com/mwd/disassembly.txt http://031d26d.namesecurehost.com/mwd/doorsw.txt If the inside light, cooling fan, and turntable are all coming on when you hit "Start" to cook, then chances are you have a failed high voltage diode or magnetron or a bad connection at the magnetron. You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
12/6/2013 1:20:38 AM • Amana ACM1580... • Answered on Dec 06, 2013
0answers
2answers
I have an amana convection/microwave model
Hi, since you have located the burnt lamp, all you need to do is to unscrew the burnt lamp and replace the new one by screwing it in.....
You only need to unscrew to remove the lamp and if you cannot remove by unscrewing because it is stuck in, then you need the assistance of an electrical tech to help remove with his pliers....
3/27/2011 4:16:18 AM • Amana ACM1580... • Answered on Mar 27, 2011
2answers
NEED THE CONSUMER MANUEL TO USE THE
You can get the manual on the link below.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/8112P236-60.PDF
Good Luck please rate 4 thumbs up and please leave a testimonial
10/16/2010 2:43:06 AM • Amana ACM1580... • Answered on Oct 16, 2010
Connection of safety switches that control the
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Our door switch help file is here.
10/3/2010 12:36:07 AM • Amana ACM1580... • Answered on Oct 03, 2010
Microwave Oven
contact 91 022 25341653
6/23/2010 4:55:19 AM • Amana ACM1580... • Answered on Jun 23, 2010
Amana aco 1840 over stove micro wave. heating not working .
FIK IT THE HEATING ELEMENT IS STRIGHT FORWORD AND COST IS CHEAP, GO FOR IT .
10/24/2009 10:48:33 PM • Amana ACM1580... • Answered on Oct 24, 2009
Amana convection/micro #AMC1580AB popping SOUND and sparks
That would be ACM1580AB, just in case that was throwing off your searches.
If the noise came from within the oven cooking cavity, it may be grease of food on or behind the waveguide cover (called a canopy in this case) which is fastened to the wall of the oven with two screws, apparently.
The cover and the area behind it must be clean.
If the canopy is burned or damaged it must be replaced.
If the sound was coming from behind the controls or on the right side under the outer cover, then it is probably a bad high voltage rectifier diode.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
(even if the magnetron passes these tests, it can still be bad. If you have high voltage and the diode is good, assume the magnetron is bad)
You can find helpful exploded view diagrams and order parts by entering your full model number here.
The actual service manual (with installation & operation info, too) is free to download here.
Your owner's manual is availabel free here.
9/28/2009 1:15:56 AM • Amana ACM1580... • Answered on Sep 28, 2009
Suddenly little power, light won't come on
Have you had trouble with your cooktop lights recently?
NOTE: FixYa's Web site is currently not notifying us when replies to our Clarification Requests are posted.
So please reply back directly to me with your brand and full model number from the tag in or on the unit for more help or free do-it-yourself tips or an estimate if required.
We're happy to help you with free advice and once we have offered you a solution, we'd appreciate your thoughtful rating of our answer.
William E. Miller
[email protected]
http://www.microwavedisplay.com
9/28/2009 12:30:04 AM • Amana ACM1580... • Answered on Sep 28, 2009
Microwave will not shut off, runs when door is
try to replace the door switches at the door latches maybe one that is defective.
9/17/2009 7:43:29 AM • Amana ACM1580... • Answered on Sep 17, 2009
Light bulb change
If the solution below does not work, please reply back with your brand and model number so we can help you.
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
8/2/2008 5:11:04 AM • Amana ACM1580... • Answered on Aug 02, 2008
Does Not Shut-Off Completely
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There may also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
4/8/2008 4:44:11 AM • Amana ACM1580... • Answered on Apr 08, 2008
Amana RCS10TS control panel inoperative (no display)
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiUw7318_L-AhX-GTQIHUoVBacQFnoECBIQAQ&url=https%3A%2F%2Fwww.repairclinic.com%2FRepairHelp%2FHow-To-Fix-A-Microwave%2F71-199--%2FAmana-Commercial-Microwave-Microwave-Display-Not-Working&usg=AOvVaw1_3-brehj_-McaojgE7G2S
5/13/2023 6:18:57 PM • Amana Microwave... • Answered on May 13, 2023
Amana ACM1580 Convection Microwave Oven Logo
28 questions posted
Top Amana Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Microwave Ovens
Most Popular Question
amana acm1580aw wnont heat
  • Microwave Ovens
