20 Most Recent
Samsung HLT6176S Television Questions & Answers
I have a Samsung Model HLT6176SX/XAA version #
This kind of symptoms indicated that the lamp is already on its peak burning life. Days will come that the picture will no longer viewable. You must replaced the lamp to back the unit in normal operation again. You may click this
LINK or obtain it to your local Samsung service centers.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
No standy lights illuminating..happened before
Sounds like a power supply issue to me. Did you check the 1.5A fuse and see if its still intact? Check it with a multimeter and measure the resistance. If it reads a very high value then its probably blown. The fuse is located on the power board(the board where your power cord plugs into the tv). Also look for any visible damage like a swollen/cracked or leaky capacitors. The top of the capacitors should be flat, if its swollen or cracked, you will know its bad.
Let me know your observations,
Sai.
I have a Samsung HLT6176SX/XAA.
Hello. I had the same problem your having. You need to replace the lamp. I bought a replacement lamp on ebay for $99.00 (Lamp code: BP96-01795A (P132W). They don't last long though. After 4 months I have hundreds of white spots on my screen.
