We are HP Printer Tech Support Team. HP printer tech support, can save your valuable time, when you spend your lots of time to repair your printer problems. SysTechConnect is one of the HP printer customer support providers which only believe in more than satisfaction of users by its better online support. You can also save your service cost by keeping get in touch with this cost-effective support. Contact us anytime. We are available 24*7.
Website: http://www.printersupportcontact.com/hp-printer
I know that HP sucks but if you insert the card into the correct opening it will work. If you are incapable of doing so, have someone else do it for you.
dv5 what , use the full model number.
what OS are you running, windows what?????
Why not get the correct HP drivers for wifi features.
from , drum roll..... HP?
ask here this is HP.
warning they wont help unless you answer the 2 questions above.
https://h30434.www3.hp.com/
Please make sure that usb drivers are installed properly in the system.
To check, please perform the following steps.
To open device manager perform following steps:
Click Start, click run and type devmgmt.msc and press Enter.
or
Click Start , enter device in the search field and select Device Manager from the list The Device Manage window opens. Now, once you are in the device manager, check it there is a yellow exclamation mark on Universal Serial Bus Controllers. If it is not expanded then expand and see if it has any exclamation mark. If you find this yellow mark, then you may have to reinstall the drivers. USB drivers for the notebook are part of the chipset. If necessary, the USB drivers required by the notebook can be reinstalled from Application recovery. If you do not see Universal Serial Bus Controllers. Then check in BIOS if computer is able to detect it. To check in BIOS, please perform following steps: Restart the computer and when the first screen displays press F10 repeatedly until the setup screen displays. Use the Left Arrow and Right Arrow keys to select the Advanced tab. Now use the Up andDown Arrow keys to select Legacy USB Support . Press Enter , select Enabled , and then press Enter .Press F10 to save settings and exit. For further details, please go through the following link. This link has complete USB troubleshooting details. http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=3687621&prodTypeId=321957&prodSeriesId=3687621&objectID=c00820529#c00820529_DeviceDetected
dear phillip james, i would like to try and help you today. could you please let me know if this error just started coming up suddenly or after a wireless card upgrade or replacement?
Problem can be;A) Graphics chipsetB) Video CableC) screen InverterD) LCD screenLet's diagnose, and find out.A) Graphics chipset:To start off with, the Pavilion dv5000 series of Notebook PC's; is NOT known to have a problem with the graphics chipset.The Pavilion dv2000 series, Pavilion dv6000 series, and Pavilion dv9000 series; does.1) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port; on the laptop.The VGA port is on the Left side of the laptop, and located towards the rear.This is a general example of a VGA connector (port), and VGA Cable,http://en.wikipedia.org/wiki/VGA_ConnectorScroll down a little for VGA Cable example.You can use a CRT type of monitor (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.Turn the monitor on. If a CRT type allow it to warm up.Turn the laptop on.By factory default settings, the display should show on the external VGA monitor. IF not:There are at least 3 display options available;1) Internal monitor of laptop ONLY2) Internal monitor of laptop AND external VGA monitor3) External VGA monitor ONLYPress, and hold down on the Fn key, and at the SAME time tap once on the F4 key. The F4 key is the Display Toggle-Over key.Still no? Hold the Fn key down again, and tap once more on the F4 key.No display on external VGA monitor, suggests a problem with the graphics chipset. (Most of the time it is a problem with the Mounting, of graphics chipset TO motherboard. If this proves to be your problem, state in a Comment )Display on external VGA monitor means the problem is the Video Cable, or inside the Display Assembly.(screen Inverter or LCD screen)B) Video Cable:The Video Cable plugs into the motherboard, in an area under the Switch Cover. (Left side. Switch Cover is the plastic cover above the Keyboard, and below the LCD screen. Has the Power On Button, LED indicator lights, etc in it)It then loops by the left Hinge, and goes up into the Display Assembly. There is a small separate wire that comes from the main Video Cable, and connects to one side of the screen Inverter.The main part of the Video Cable goes on, to connect to the back of the LCD screen.Example of Video Cable,http://www.batterycentury.com/hp-430531-001-cable-p-215726.htmlClick on image to enlarge.The wide connector you see at the top/left, connects to the back of the LCD screen.The wide connector at the bottom/right, connects to the motherboard.The single cable (Wire) coming off at the bottom, connects to one side of the screen Inverter.Just due to normal repeated opening, and closing of the laptop; the Video Cable may become pinched.This leads to it being pulled on, and may also lead to damage of the Video Cable.(Stretched/Broken wires)Procedure is to Physically check the connections of the Video Cable. Visual inspection alone will NOT do. You need to physically see if you can plug the connection in tighter.1) ALL power removed. Remove the AC adapter (Charger), and Battery.2) Remove the Switch Cover.[Switch Cover is just that. A Cover. I will give a link to a free Service Manual from HP Support, towards the bottom of this solution ]Try to plug the Video Cable connection at motherboard, in tighter.Once done reinstall the Battery, and attach AC adapter. Plug AC adapter into power.Turn the laptop on.Still no? Turn laptop off. (Hold down on Power On button)Remove ALL power again.This time check the Video Cable connections at screen Inverter, and back of LCD screen.The plastic frame in front of the LCD screen is the Display Bezel.Example,http://www.ebay.com/itm/447997-001-HP-Pavilion-LCD-Display-Bezel-DV9000-Series-w-Webcam-GENUINE-/170992584210?pt=US_Laptop_Screens_LCD_Panels&hash=item27cff3c612Service Manual indicates to remove Display Assembly from laptop, in order to remove Display Bezel.IMHO this = NO.I think you can remove the Display Bezel, without having to remove the entire Display Assembly.This video details removing the Display Assembly.Shows replacing the LCD screen. http://www.youtube.com/watch?v=NNyvf4KqeIYWhat my concern is with removing the Display Bezel, is the integral Hinge Covers that are a part of it.I believe the Display Assembly can be tilted far enough back, that the Display Bezel can be removed, and carefully ease the Hinge Covers out/off at the same time.Why not just remove the Display Assembly?A whole lot less stuff to reconnect, after you have checked the LCD screen connection of the Video Cable, and screen Inverter connection.After disconnecting the LCD screen from the Hinge Brackets, you just tilt the LCD screen forward, and check the Video Cable connection.Then slightly tilt the Display Cover back, so the LCD screen can rest against it, and reinstall power.Connections are plugged in tighter, and this proves to Not be the problem, go on.(Don't forget to remove ALL power again)The Screw Covers are made of synthetic rubber, or plastic.They are held in place by a type of rubber cement.I like to use a computer pick, (Much safer than a blade!), and lift up at the base of the Screw Cover.I also like to GENTLY stick them to the Display Bezel for safekeeping. (They like to stick to the tool, your fingers, and it seems passing cars. "Oops, dropped one. Where'd it go? Hmmmm)If you are careful with them you can reuse them. (Doesn't stick anymore? Apply a TINY dab of rubber cement to them, with a toothpick)Screws removed, I suggest cut a piece of thick construction paper, that just fits the inside edges of the Display Bezel.Helps prevent scratching the LCD screen, from your fingernails, when you go to flex the Display Bezel, and remove itThe LCD screen is an Assembly of layers. They are held in the factory aligned position, by the metal Screen Frame which surrounds them.There are screws that hold the Hinge Brackets TO the Screen Frame, and there are screws which when removed, will take the Screen Frame apart.ONLY remove the necessary screws which hold the Hinge Brackets, TO the Screen Frame!More in a Comment.Regards,joecoolvette
Get onlineand got to www.google.com In the google search box type: "HPSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for Manuals an see if any give you any instructions on taking the laptop apart.You can do it without a manual. Just have come small paper cups that you label to hold the screws and a digital camera to take photos. Turn the laptop over and start removing screws from the bottom. Then remove the battery, the hard drive, the memory, the wireless card, the dvd drive. Look inside the battery case and there might be screws inside it to remove. There might also be some inside the hard drive or dvd case to remove. Take note of the screws that might have the icon of a keyboard beside them (these hold the keyboard in place). After the screws and devices are removed from the back, turn the laptop over and remove the strip (be careful there might be a cable under the strip) that is just above the keybord (sometimes it might be attached as one big piece to the palmrest). One the strip is removed, remove the keyboard (be careful there is a cable under the keyboard). Next remove the LCD Screen by removing the screws that hold it at the corners and also pull the cables from the wifi and lcd cable. Afterwards remove the palmrest there will be cables attached to the palmrest. Once the palmrest is removed you can start removing screws that hold the motherboard to the bottom base, then lift out the motherboard.
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your ((motherboard to your hard drive)) Sata make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause you problems
a computer needs all of the data and electrical current to travel through every working device and to have an end for a computer to be able work properly
make sure your graphics card is securely seated with no dust in its socket
if you physically remove your graphics to check the socket card restart your computer this should activate found new hardware wizard
if still no luck you could go for the extended desktop
you will need to connect the television to your computer with the vga monitor connection
click start control panel display change display settings adjust resolution this may vary depending on your operating system you should a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system
when you select the no 2 tab this should be the extended desktop always click apply after making any changesor click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes
if the extended desktop works your lcd screen may be faulty and needs to be replacedhope this helps you
As you have found... half a volt at that amerage should be just fine...
If it helps, I just bought an aftermarket replacement of the correct voltage and amperage for my nx9010 from eBay for $15AU delivered. It'd probably help when it comes time to sell your laptop =-]
Check that wireless service is running XP: Click Start, click Run, type services.msc, then press Enter.
Scroll down to "Wireless Zero Configuration" and right click on it and select
Properties. Set it to Automatic and not Disabled, and press the Start
button, then click OK.
That should start the service. 7 (vista): Click Start, type services.msc, then press Enter.
Scroll down to "WLAN AutoConfig" and right click on it and select
To enable wireless adapter we need to go to device manager and enable it. XP: 1. Right click on My Computer and click on properties. 2. Click on Hardware tab on system properties window. 3. Click on Device Manager To go to device manager we need to click on the device manager button. Now we can see all the hardware devices connected to the computer. To see the status of our wireless adapter click on network adapters. 4. Enable the Wireless adapter To enable wireless adapter, right click on it and click on enable. 7 (vista):
Open the Start Menu by clicking the Start button. Click on Control Panel.
In the Control Panel, click on Network and Internet.
In the Network and Internet panel, click Network and Sharing Center.
In the Network and Sharing Center, click "Manage network connections" in the Tasks list on the left side of the window.
The Network Connections manager will open. Right-click the icon labeled Wireless Network Connection and click Enable on the menu displayed.
The last step checks if you have the wireless switch on or off. Locate the wireless button (in the middle, above the keyboard). Try to toggle it, see if is says anything.
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?right click to reinstall drivers or if you can see your usb drive but its not workingports(com&lpt)right click update driver or scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall hope this helps
I will give you a easiest way for finding the drivers that you
needforyour hardware.Just download the software named
drivermagician.Installit and it will search for the drivers that is
notinstalled for thehardware you have through internet and will
downloadit for you.
