20 Most Recent
OKI C3530N Color MFP Printer Questions & Answers
Paper jam but no paper is jamed in printer
I have had this issue before. I hope this helps you. Try these steps:1) Open the the top cover; then close it..read the message on the screen. If it doesn't resolve..2) Remove paper and insert a fresh stack of paper. Making sure that edges are smooth..no creases or wrinkles.3) Open paper feed area. If you have pipe cleaners available, clean each opening. You can use the fine hose attachment from a vacuum to do the same thing, if needed. Proceed to close the paper feed compartment..read the message on the screen. If it doesn't resolve..3) Turn off the printer for a few minutes; then power it back on. Printers 'read or sense' the paper as the printing job occurs. Even the smallest shred of paper can cause the printer to identify it as a paper jamI hope this helped you.
My C3530 prints misaligned on
Welcome to FixYa!
Solution one: Make sure that paper is loaded correctly
Check the following:
- The right side of the paper is flush with the right side of the paper tray.
- The paper guides are snug against the edges of the paper.
- The paper is flat in the tray.
- Make sure only one type of paper is loaded in the product.
Solution two: Restart the printer and computer.
- Turn off the printer.
- Unplug its power cord from the power source.
- Unplug the USB cable at the back of your printer (if your are using one).
- Restart the computer.
- After the computer restarts, connect back the USB cable and the power cable.
- Turn on the printer and try to print.
Keep me posted.
Jas247
