20 Most Recent Philips 50MF231D 50 in. Plasma Television Questions & Answers
The power supply could be failing.
Philips 50MF231D... | Answered on Jul 22, 2017
if you are using the TV with a cable receiver, connect the TV to a DVD player, make sure all volume are turned on and observe if the TV will bring an sound.
If you don't hear any sound, then it means the audio chip/sound IC is defective, or maybe it has been tampered with unknowingly, when fixing the power problem.
Again, one way to confirm if actually, the audio chip/sound IC is the cause of the problem, connect a earphone to the TV headset part and if you do not hear any sound, then it means the audio chip/sound IC is the cause of the problem.
So, cross check the audio chip/sound IC, read it with a meter to know if it's defective. If its defective, make necessary replacement, just like you need when replacing the 2 blown caps on the power suppl board of your TV.
I hope this helps.
Good luck.
Philips 50MF231D... | Answered on Dec 02, 2010
If you remove the back, you might see a couple of electrolytic caps that are bulged on the power supply, that need to be replace, or just replace the power supply itself. There are also two readings, that you can read, the VA voltage and The VS voltage. There will be a label on the inside on the back farme that will tell you what the VS, VA, voltages should read on the output of the power supply.
Philips 50MF231D... | Answered on Nov 12, 2010
if its old non hdmi forget it blu ray demands to high ?
Philips 50MF231D... | Answered on Jan 05, 2010
Take the back off of the TV and look at the power supply board (middle of the set). One or more electrolitic capacitors will have the tops swelled up. Replace them with the same value parts and you will be OK.
Philips 50MF231D... | Answered on May 21, 2009
Should have been 3300 UF 10V caps that were bad? Shouls have been replaced with 3300UF 18V. 50V is huge. If it was replaced with a 50 the polarity may be wrong or the cap it too big to be seated property. Sometimes the caps just dry out and even a normal looking one will be the culprit of no OSD. Are you getting an LED fault code blinking? That should be a red led. Do you hear the relay clicking.? When you replaced the caps did you charge them? Just plugging in the set without trying to power it on for about 20-30 mins. I may be able to help you
gysgt2u1@yahoo
Philips 50MF231D... | Answered on May 08, 2009
you may have accidentally pressed one of the wrong button at the bottom of the remote control. the codes are in the back of the user manual
reepende a donde vivas si vives en mexico las venden en mercado libre si vives en otro pais em EBAY o en tiendas de electronica y en tu localidad en un desguesadero de electronica si eres usuario mejor lleva tu pantalla con un especialista,y si eres tecnico consigelas en donde ya mencione.
Philips... | Answered on Sep 08, 2019
Applicable codes will be found in a compatible remote control.
Philips... | Answered on Aug 29, 2019
Hi Anonymous, search Google, LCD Panel for Philips TV 55PUT6233 / 56
Keep in mind that replacing the panel has its risks
Good luck in the search
Regards Franco Dosil
Hola Anonymous, busca en Google, Panel LCD para TV Philips 55PUT6233/56
Ten en cuenta que reemplazar el panel tiene sus riesgos
Suerte en la busqueda
Saludos Franco Dosil
Philips... | Answered on Aug 24, 2019
  • Make sure that all words are spelled correctly.
  • Try different keywords.
  • Try more general keywords.
  • Try fewer keywords.
Philips... | Answered on Aug 22, 2019
Philips 50MF231D 50 in. Plasma Television Logo
15 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
fix magnavox tv keeps blinking
  • Televison & Video
