20 Most Recent
Leica Digital DISTO D3a 100M Laser Distance Meter Questions & Answers
What does error 270 mean?
There is no error code 270 listed for a Leica Digital DISTO D3a 100M Laser Distance Meter.
Are you sure that's the code?
Or do you have a different make or model of laser distance meter?
Leica Disto A5 does not measure with the main button, but it does measure with the timer
It's possible that the main button may be malfunctioning or broken, which is preventing it from activating the laser. Here are a few troubleshooting steps you can try:
- Ensure that the laser is not obstructed or dirty. Use a soft, dry cloth to wipe the lens clean.
- Check the battery contacts and make sure they are clean and properly aligned. You can clean the contacts with a cotton swab and rubbing alcohol.
- Try resetting the device by removing the batteries for a few minutes and then reinserting them.
- Check the user manual or manufacturer's website for any firmware updates that may address the issue.
If none of these steps work, it may be necessary to send the device in for repairs or contact Leica customer support for further assistance.
Will one of the newer sensors work in place of my 1457 sensor?
It's possible that one of the newer sensors could work in place of your 1457 sensor, but it depends on the specifications of the newer sensors and the compatibility with your base unit. The I MAX1457 sensor, which is a highly integrated analog-sensor signal processor optimized for piezoresistive sensor calibration and compensation. However, I have no information about its compatibility. If you're looking for a replacement sensor, I suggest contacting the manufacturer of your base unit to inquire about compatible sensors. Alternatively, you can check the user manual of your base unit to see if it lists compatible sensors. Garage door opener sensors are not universal. Safety sensors can only communicate with garage door openers from the same brand.
