20 Most Recent Samsung S830 Digital Camera Questions & Answers
sorry but we do not remember either ,perhaps Samsung tech support can assist you.
Samsung S830... | Answered on Aug 09, 2015
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Samsung S830... | Answered on Aug 02, 2013
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Samsung S830... | Answered on Apr 11, 2013
The S830 uses two standard AA batteries.
Samsung S830... | Answered on Dec 27, 2012
I bought a second broken camera on ebay and used it for spares then resold it detailing the faults
Samsung S830... | Answered on Jan 05, 2012
Buy an old or broken camera on ebay etc and use catch I did this.
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
Samsung S830... | Answered on Apr 28, 2011
Chech wether something is not stuck between yopur lenses of camera.....it is dfue to...that something is stoping the lenses to come out...there might be something betwwen lense and camera walls...check it out..
Samsung S830... | Answered on Oct 24, 2010
Just go into the menu and find "format"...follow the on-screen instructions.
Samsung S830... | Answered on Oct 15, 2010
To change or replace a digital camera battery in UK,Go to the Wholesale battery warehouse.
Samsung S830... | Answered on Jun 23, 2010
You may have protected a block of images at some time, to release them do this:
Press the play mode button and then press the menu button.
Press the left/right button to select the [Protect] menu tab.
Select the desired sub menu [All Pics] by pressing the up/down button then pressing OK.
Zoom W/T Button: Protect/Release the images.
OK Button: Your changes will be saved and the menu will disappear.
Hope this helps.
Samsung S830... | Answered on Feb 06, 2010
Make sure you're in a recording mode other than VOICE.
Press the Self-Timer button (right button) until the display shows the desired mode. Your choices are 10-second mode (the camera takes a picture ten seconds after you press the shutter button), 2-second mode (the camera takes a picture two seconds after you press the shutter button), and Double-self-timer (the camera takes a picture ten seconds after you press the shutter button, then takes another two seconds later).
You can cancel the self-timer mode by pressing the Self-Timer button again.
The 10-second mode allows you to run back for a group picture. The 2-second mode is useful when you want to take a picture without fear of camera shake; simply place the camera on a steady support such as a tripod. The Double mode increases the chances of getting a picture with everybody's eyes open.
Samsung S830... | Answered on Jan 11, 2010
Hi there.
The camera is asking you to format the camera card.
If you have any pictures you want on the card, connect it to a PC and transfer the data from it, then put it back in the camera and do what it asks you too do.
Thanks for choosing FixYa!!
Samsung S830... | Answered on Jun 08, 2009
emm... I have got an 2 gb SD memorycard for mine to and it wont work. Read on several places that the camera can only handle 1 gb memory card... Dont know if that's true thou.
Samsung S830... | Answered on Apr 23, 2009
Easiest way is to remove the media card from the camera and put it in a USB card reader attached to your laptop, which will then see the card as a new disk drive
Samsung Cameras | Answered 3 days ago
Consult your network provider
Samsung Cameras | Answered on Jul 22, 2019
the only place i've found to get one is through the samsung website, and you have to go their accessory page and you can get it:
Samsung Digital Camera USB Data & Charger Cable Type12 SUC-C3
Samsung Cameras | Answered on Jul 01, 2019
Samsung S830 Digital Camera Logo
22 questions posted
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
View Most Popular
Samsung Cameras
  • Samsung Cameras
Most Popular Question
s830 not capatable windows 8 cd wont
  • Cameras
