20 Most Recent RCA L42WD22 42 in. LCD Television Questions & Answers
Failed Firmware Update
You have learned a painful lesson the hard way - never do an upgrade or firmware upgrade unless it is absolutely necessary to do so. Often, the procedure fails and you are left with a nice paper weight. Bet you that you did not save the original firmware (or were not given the chance to do so). If you cannot get it from manufacturer you are SOL. But you have learned, haven't you? Good luck with RCA.
8/26/2017 8:10:09 PM • RCA L42WD22 42... • Answered on Aug 26, 2017
Sound no picture
Its a common problem for this model.
1. Is there any flash of light from the backlights (best viewed from the back of the TV with the back removed)?
2. Have you tried shining a flashlight on the screen to see if a display is present when power up?
There are three possible failures.
1. A failure in the main board.
2. A failure in the LCD panel / Tcon
3. A failure in the inverter / backlight system. This could be as simple as a blown fuse.
Thos three failures would mean it needs to be service.call RCA
4/20/2017 12:11:02 PM • RCA L42WD22 42... • Answered on Apr 20, 2017
Fixing my RCA tv
I would just replace it and stop the future bleeding of money unless you have the manuals and test gear and the training to really know what you are doing.
9/8/2016 12:53:15 AM • RCA L42WD22 42... • Answered on Sep 08, 2016
POWERS UP BUT SOFTWARE UPDATE SCREEN SHOWS UP
Update the software. It is necessary.
5/23/2016 2:49:10 AM • RCA L42WD22 42... • Answered on May 23, 2016
Power is getting to the power box but not to the rest of the TV.
Fault to the main power supply regulator section. It is not oscillating. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
2/27/2016 3:50:32 PM • RCA L42WD22 42... • Answered on Feb 27, 2016
2answers
My 42" tv has a picture but no sound the sound started cracking then stopped and i cant get no audio
Look first to see if you have audio when a DVD etc. is connected to the audio/video input this set has on the rear.
5/26/2015 3:25:49 AM • RCA L42WD22 42... • Answered on May 26, 2015
2answers
TV keeps asking for upgrades. After attempts to
Did you get this from the RCA website, if so call assistance and get RCA to help you through the upgrade.
5/13/2015 4:34:53 AM • RCA L42WD22 42... • Answered on May 13, 2015
Oftware upgrade application RO.8L12.8.01 keeps coming on cant get it to leave for hrs. sometimes cant view programs while its in this screen mode
Noise in 5 volt standby voltage may have already corrupted eeprom. Change the two 680uf/16 volt and other bloated caps in power supply to see if tv is still salvagable.
5/13/2015 4:29:16 AM • RCA L42WD22 42... • Answered on May 13, 2015
How to adjust color on rca 1080
You have to enter its service mode option to adjust this. There is adjustment facility in the "White balance" adjustment choice. Contact any service technician. To get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
9/1/2014 3:05:10 AM • RCA L42WD22 42... • Answered on Sep 01, 2014
How to reset rca tv
Hmmm, if you're using an antenna then go into the menu on the TV and hit the Scan for channels button. If it's a Cable box then make sure it is connected correctly and on the right input.
8/22/2014 8:18:26 PM • RCA L42WD22 42... • Answered on Aug 22, 2014
Need to program remote for my tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/
8/16/2014 3:39:17 AM • RCA L42WD22 42... • Answered on Aug 16, 2014
Auto scan channels rca flat screen
Refer its user manual for details.
7/18/2014 4:42:01 AM • RCA L42WD22 42... • Answered on Jul 18, 2014
RCA L42WD22 42 in. LCD Television Logo
232 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
screen goes black but still hear sound
  • Televison & Video
