20 Most Recent
Laser MVP-1G MP3 Player Questions & Answers
When I plug my headphones into the audio output
Either your jack on the earphones is bad or the female end on the player is bad. Your not getting good continuity going to the speakers in the earphones. Try another set of earphones. You may be able to clean the jacks with alchohol and see if this clears it up. Sounds like a broken wire in the headphones to me!
It will only hold about 20 songs (its 2gb) and
Plug your player into your computer with the USB lead,
Open MY COMPUTER and see the removable drive.
Right Click and select FORMAT
Note - this will delete everything on there but lets you start again and should hold many more songs
Hope this helps
Laser mp3 2gb
Check the laser co downloads area for user manuals.
Why is it that it takes around 12 hrs for my laser
Your internal rechargeable Lithium battery must be getting old and therefore starting to loose its capacity to charge completely. Another symptom is significant reduction in Total play time and faster discharge on standby.
My new bought Mp3 player is malfnctioned
in such cases, may be data cable is damaged.
so u can buy a new data cable and check again.
if it will not help u, then check the follow link, which help u to reset your ipod:
http://mympxplayer.org/viewtopic.php?printertopic=1&t=567&postdays=0&postorder=asc&start=0&finish_rel=-10000
Put songs on player
hello sir
its a technical problem in all the mp3 devices not only your so calm down.......here is your solution
plug the device to your computer> then go to my computer>
right click on your device > click format> then format it...
unplug it then again plug it and load some songs in it
and try to listen
regards
golu_fixya
Laser v-mate MP4 player
from your desktop select <START> then <PROGRAMS> <ACCESSORIES> <PROGRAM COMPATIBILITY WIZARD>
If you cant see "Getting older programs to run on Windows XP" in the box for "Fix a problem" then type it into the search box. It will bring up a program with instructions to follow to allow the windows 98 driver to run on your operating system.
It worked for me, now I just have to figure out what to do with it
Laser mvp-2G
ok thats easy matie.. u have to go into dos shell and type "(the drive letter) /FS:fat32" if this doesnt work download FDISK and run it in shell or if u have a old windows installation disk u can get it off that rip it onto your mp3 and boot your pc off it then open fdisk and recreate a fat32 partition on mp3 i had same problem with laserco media player. Hope this helps
