20 Most Recent Vivitar ViviCam 6320 Digital Camera Questions & Answers
I have a Vivitar Vivicam 6320. There was an AC adaptor but that has been mislaid. I would like to use a generic adaptor. Any help would be appreciated.
There are universal adapters that have several common voltages with a selector switch. They come with different style interchangeable plug ends, so one of them will fit your camera. Original Power Powerline 1300 mA Universal AC Adapter One similar to this will work well for you.
12/11/2016 4:41:00 PM • Vivitar ViviCam... • Answered on Dec 11, 2016
Switches on and imedietly switches off again and lens will not retract
Pete, I've had cameras that have done that before, and I was advised they were broken. Not worth fixing either. It may have been dropped or handled roughly. That may not be the case for you, but its happened 3 different times to me. Different cameras too.
1/8/2015 10:50:09 AM • Vivitar ViviCam... • Answered on Jan 08, 2015
I have last my installation cd
You don't need to install any software in order to use your camera.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
1/28/2013 12:18:17 AM • Vivitar ViviCam... • Answered on Jan 28, 2013
Cd rom
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
8/8/2012 5:41:17 PM • Vivitar ViviCam... • Answered on Aug 08, 2012
I bought a 4g memory card and it will not format.
The 6320 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in devices not designed to take them. You will have to use SD cards, 2GB and smaller.
7/8/2012 5:45:25 PM • Vivitar ViviCam... • Answered on Jul 08, 2012
I have a ViVitar ViVicam
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
9/6/2011 6:23:01 AM • Vivitar ViviCam... • Answered on Sep 06, 2011
I have a vivitar vivicam
Could be some protection mechanism of lens stuck problem.
9/2/2011 4:08:43 PM • Vivitar ViviCam... • Answered on Sep 02, 2011
Camera was functionationg ok. Now
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
6/22/2011 6:48:17 PM • Vivitar ViviCam... • Answered on Jun 22, 2011
Cant upload photos
Try NOT connecting your camera to your computer.
5/13/2011 5:34:55 PM • Vivitar ViviCam... • Answered on May 13, 2011
Battery door broken
The best is to piece up the broken parts and GLUE them using good super glues available in the market. If the broken pieces are beyond repair then the door must be sourced from Vivitar.
If an old one can be found from any dealer it will be worth a try.
2/4/2011 10:44:57 AM • Vivitar ViviCam... • Answered on Feb 04, 2011
Need user manual vivicam 6320
Hello
OK, you will be able to download the manual HERE.
Kind regards
Andrea
8/29/2010 9:11:05 AM • Vivitar ViviCam... • Answered on Aug 29, 2010
How do I download photos to my computer?
Hi! If the cam comes with a usb cable, you can link it from the cam to the computer using the usb cable. If it comes with a memory card, you can use a card reader that is use for pc. By doing this procedure it will open a new drive on MY COMPUTER and you may access the files from the cam. HOpe this helps and have a good one!
5/23/2010 10:31:51 AM • Vivitar ViviCam... • Answered on May 23, 2010
My vivitar vivicam 6320 works ok but flattens
use energizer rechargeable batteries and will work for good
2/25/2010 3:54:00 PM • Vivitar ViviCam... • Answered on Feb 25, 2010
Camera comes on then goes off immediately. i have tried other bat
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
12/8/2009 8:43:50 PM • Vivitar ViviCam... • Answered on Dec 08, 2009
I am trying to upload my pictures from the camera
Use a card reader to download your pictures to a folder you create on your desktop.
9/29/2009 9:02:31 PM • Vivitar ViviCam... • Answered on Sep 29, 2009
Vivitar vivicam 6320 keeps turning off
Batteries?
9/22/2009 6:11:42 PM • Vivitar ViviCam... • Answered on Sep 22, 2009
How do I downlaod pictures from my vivicam 6320
Most cameras have a port to plug in a wire to connect to your computer. To use it, you will most likely have to install the software that came with the camera. If you do not have the software, go to the manufacturers site and see if they offer downloads of it.
A faster way to transfer images is to take out the memory card and insert it into a "card reader". If you do not have a card reader, you can buy one for cheap from anyplace that deals with computer parts. I suggest a site called newegg.com. Also worth mentioning, you do NOT need the camera software when using this method.
9/14/2009 8:02:25 AM • Vivitar ViviCam... • Answered on Sep 14, 2009
A user's manual that I can dowload and print at no cost
Go to www.retrevo.com and download manual in pdf form. ted10
5/12/2009 6:30:23 PM • Vivitar ViviCam... • Answered on May 12, 2009
Vivitar ViviCam 6320 Digital Camera Logo
Popular Tags
23 questions posted
Top Vivitar Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
View Most Popular
ViviCam Vivitar
  • ViviCam Vivitar
Most Popular Question
vivitar vivicam 6320 ac adaptor but
  • Cameras
