20 Most Recent
i-mate SP3i Smartphone Questions & Answers
Bluetooth
hi thanks for using fixya!
Please follow the instructions below:
1. Tap Start Menu
2. Tap Settings Menu
3. Tap to got to Connections Menu
4. Tap Beam, and tick the "Receive all incoming beams", then close it
5. Go to the Bluetooth, you must add new device, make sure that your bluetooth is turned on and the other device must be turned on and visible for you to search it.
6. And there you go, just follow the next steps from your pda and you will be able to send and receive datas via bluetooth.
If you need further assistance, let me know!
Don't forget to rate me positively! thanks!
Imate SP3 PC suite
you should find in internet software realated your phone only not others. THANX
I cant send data via bluetoorh
When you are receiving the file, check whether you have checked the Visible to other option. And it will ask for the confirmation when you will be receiving the file from other phone whether to accept or not. While sending the phone to which you are sending data should accept the file you are sending.
Let me know if you have any comments.
Cannot unlock even after trying
Please try to remove the battery. And try to do the hard reset. Perhaps, you are experiencing software error.
If you need further assistance, let me know.
I-mate SP3i how do I send data with bluetooth
Use a file manager like Resco Explorer - select your file to share - on the Action soft key - Send to - Bluetooth recipient.
http://www.download.com/Resco-Explorer-2005-for-Smartphone-English-/3000-11139_4-10694621.html
Dismantling Imate SP3i
no idea if u have resolved the issue . but here is a guide . Back bottom of the phone two long screws . Under battery there is two screws one top left and one under the void sticker . Then take off the cover over the camera and there will be two more screws . slowly clip off the back case . Then this will reveal the m/board for the phone in the centre there will be a phillips screw wich releases the keypad from the front of the phone .
Hope that helps
Imate Sp3i
check your profile status and keep the volumes in high level.
