20 Most Recent
DXG Technology DXG-538 Digital Camera Questions & Answers
,y DXG 538 digital camera has no flash and pictures in screen
ok, for starters, the 4028x1260 is the resolution, meaning, the picture quality and shape...in computer terms, the number of pixels in the picture...the higher the number the better...usually
anyway, to turn on the flash, push the "Set" button. in the lefthand side of the screen...i think. will be a symbol that changes. the A means automatic, the O with a line through it means no flash, and the others are useless.
to make them brigter, in the menu you should see a thing that says E.V. {somenuber}.{someOTHERnumber}
ie. 0.0, 0.5, 1.0, 1.5, 2.0 and it goes to negative 2.0 as well.
the higher the number the brighter the pic
I NEED A MANUAL
Try
http://camera.manualsonline.com/manuals/mfg/dxg_technology/dxg_dxg538_digital_camera.html
(all on one line).
I can't upload pics.
If you're talking about a USB cable with the "Mini-B" connector that goes in the camera, you or someone else could have stepped on it or yanked it somehow. I have had a couple cables like that get bent to the point they won't work. If the cable looks straight still, then it could be something else. But its a thought.
DXG-538
Camera comes on but no picture showes in viewer.
Re:drivers
yeah, same here...:\ it was fine with XP...
How to download to computer
You didn't specify the model of your DXG camera so I'm going to assume it uses a memory card of some type.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa (
http://picasa.google.com ).
Just pt in a neww
You must have pics on the internal memory. That's what the camera is telling you. You should format the internal memory with no card in the camera. Then, insert the card and it should work properly.
My open view is not showing any pictures but showing information about programs playing what might be the problem
Some steps you can try:
Check Picture Location:
Ensure that the pictures you want to view are in the same folder location. Sometimes, if the images are scattered across different folders, they may not appear correctly in the photo viewer.
Repair or Reset the Photo App (for Windows 11):
Go to Settings > Apps > Photo.
Click on Advanced options.
Choose either Repair or Reset to address any potential issues with the Photo app.
Enable Thumbnail Previews (for Windows 10):
Open File Explorer Options:
Type "file explorer options" in the Windows search bar and select the first result.
Switch to the View tab.
Ensure that the option "Always show icons, never thumbnails" is unchecked.
Click Apply and then OK to save the changes.
That is about all I can offer. If you repost, include brand and model.
4/19/2024 8:18:20 PM •
Cameras
Answered
on Apr 19, 2024
