20 Most Recent
Oakley Thump 2 MP3 Player Questions & Answers
Thump pro speaker
16mm. 16ohm 5.4mm high and so far impossible to find. You will have to find a donor pair of glasses
Connection not recognized
I have often had the same problem. Resetting the software enabled me to recover. Press and Hold the Play/Pause (center) button and the Previous Song/Rewind (rear) button•at the same time. I held it for about 5 seconds. Then I released both buttons, then pressed the Play/Pause for about 1-2 seconds, the unit powered up and I was able to connect and charge the unit.
• If the reset procedure does not work, you may need to restore the internal software.See your .pdf users guide, this will erase your song list.
Good luck.
My Oakly O ROKR SUNGLASSES BLUETOOTH NOT WORKING
Your question does not really help me with working out the problem, check out my website.
www.oakleythumprepair.com Orokrs have several problems, mostly battery and sweat damge will be the cause, or someone has opened them! I see Thumps and Orokrs that have been sent to me for repair, returned to the customer unfixable with a clear description of why, only to see them listed on eBay as not charging or wont turn on, not tested ect.
Just got some oakley thump
If one speaker is not working, then the chances are its either the Speaker itself or one of the two wires. Speakers and replacement wires with the JST connector are now available. If the glasses power up, make the THUMP sound and power down Its the battery, same if they only last a short time. Most faults are Battery, Sweat Damage, or damaged ribbon cable.
