20 Most Recent Amana ARS266ZBS Side by Side Refrigerator Questions & Answers
My may tag fridge GS2126PADB seems to run fine but the freezer is not blowing cold air and fridge & freezer are warm.
There are more than reason: first check the fan in the upper part of the freezer (you have to unscrew 3 bolts of the cover),second check the freezer door sealing,third is to check that the cooling tubes inside the freezer are cold enough without heavy snow (you have to unscrew about 6 bolts of the cover),Heavy snow reduces cooling and it means that the timer is not working or the heater is not working.I hope to help you in reform
6/30/2014 10:10:03 PM • Amana ARS266ZBS... • Answered on Jun 30, 2014
My freezer is blowing warm air and seems to run but both fridge and freezer are room temperature.
That means that either all of your coolant has escaped (e.g. leak in the pipe) or that your compressor has blown.
6/27/2014 5:37:48 PM • Amana ARS266ZBS... • Answered on Jun 27, 2014
134a pounds drs2662a
it will tell you on the tag with ser# and model refig type and oz or lbs
10/23/2013 10:28:47 PM • Amana ARS266ZBS... • Answered on Oct 23, 2013
Fridge too cold, switch is on 1 and temp. Is 2 deg C. What can be the problem
Looks like you might have a bad damper assembly. See the diagram HERE. It is number 5 in the diagram. If this is not closing, it will let to much air into the refrigerator section. Check with your hand to feel if air is still coming into the refrigerator(fresh food) section. There should be a little air felt but not much. If there seems to be to much, it is probably the damper not closing. You can also remove the panel were the damper is to see if the door is closing. Remember to clean your condenser and to see other Amana problems CLick Here.
4/4/2013 8:53:59 PM • Amana ARS266ZBS... • Answered on Apr 04, 2013
How long is it supposed to cylce/stay on (fan/motor) ?
Depends on how clod it needs to get.
11/20/2012 1:07:10 PM • Amana ARS266ZBS... • Answered on Nov 20, 2012
Amana side by side SQD23VW replaced defrost timer and still ices up
You need to replace the "defrost thermostat" that is located on the coils behind the freezer wall. Here is the part you need.
10/20/2012 12:22:40 PM • Amana ARS266ZBS... • Answered on Oct 20, 2012
I have a older amana
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
8/24/2011 10:32:24 PM • Amana ARS266ZBS... • Answered on Aug 24, 2011
I have an Amana refrigerator
The data for the refrigerant should be on the model/serial number tag. the total charge is typically around 6 ounce of R134 that is the only refrigerant that can be used. Any stop leak if very likely going to block the cap. tube the inside diameter of it is about the thickness of two stands of hair which you know aint very thick at all
8/9/2011 4:37:14 PM • Amana ARS266ZBS... • Answered on Aug 09, 2011
Amana side by side refrigerator wont cool properly after moving
have a two year old side by side amana frig. the freezer side works fine, the frig is at 56 degrees at coldest setitng. HELP, can't get repair guy for five days cause we live in rural area.
8/9/2011 1:55:39 PM • Amana ARS266ZBS... • Answered on Aug 09, 2011
I have a side by
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
7/12/2011 1:42:04 AM • Amana ARS266ZBS... • Answered on Jul 12, 2011
My freezer seemed to have quit so I cleaned it out
open the freezer door,do you hear the fan blowing around?it sounds like the evap fan motor isn't running and that's why it's cold on the bottom and not the top,you have to repair this fast or you'll loose your food in the fridge,the fan is what blows the cold air from the freezer to the fridge section.
5/8/2011 12:08:27 PM • Amana ARS266ZBS... • Answered on May 08, 2011
Amana ARS266ZBS Side by Side Refrigerator Logo
156 questions posted
Top Amana Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Amana Refrigerators
  • Amana Refrigerators
Most Popular Question
freezer blowing warm air seems run but
  • Refrigerators
