20 Most Recent
Jazz DV165-BOX Digital Camera Questions & Answers
Jazz dv 165
Places to look
If you have the supplied DVD - may be in PDF file
Manufacturerer web site
or take a trwel through thishttp://www.google.com/search?q=DV165-BOX+Digital+Camera+%3E&sourceid=navclient-ff&ie=UTF-8&rlz=1B3GGGL_enGB260GB260
Cd rom for downloading pictures
The best way, removing the memory card from the camera and plugging it into acard reader. (Either you connected via USB or FireWire and won't run down yourcamera's batteries.) It will be faster than connecting the camera to thecomputer. Once the card is plugged in, it will appear to your computer as aremovable drive. Now you can get copy paste facility. You can easily copypictures from the card to the computer's hard drive.
Hope this helps.
Let me know if you need more information
Thanks
How do i take a picture?
under the menu option you can cycle thru till you see camera mode and diff mega pixel options. i believe there also may be a switch on that model i have a previous model.
Sd card not formating
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
THE BACK PIECE FOR THE BATTERY FELL AND I LOST IT
These are the brands and type of AA batteries that you may use in Jazz DV165-BOX.
1. Ni-MH rechargeable battery (Empire and Powerex brand)
2. Ni-Cd rechargeable battery (Sanyo brand)
3. Lithium not rechargeable battery (Energizer E2)
4. Alkaline not rechargeable battery (Energizer brand)
The site where you can see their prices and make order is
http://www.batterycanada.com/pro415.asp Please comeback and give some ratings. Thank you for using Fixya.
Can't install the cd with vista
Unfortunately this is a company with horrible support and you are basically out of luck. Though for as little as 50-60$ you can purchase a new camera by a reputable company that will be at least twice as good.
Thanks,
Lee
Jazz DV165... remove date from pics
Go under settings and there should be something that says date stamp or something like that. Then select it and there should be an off choice. Select it and the date stamp is gone.
Hope this was helpful!
Logan
Computer plug in
whats your OS....call technical support X116 Mike Z
customer service X140 Abby
1-800-983-7004
