20 Most Recent Sharp LC-26SH10U 26 in. LCD Television Questions & Answers
2answers
Hdmi sound and picture
After reading your post I can't understand what are you doing and what you expect to achieve
3/7/2018 3:38:50 AM • Sharp LC-26SH10U... • Answered on Mar 07, 2018
I have picture ,but no sound
Test: You might see a pic by shining a bright light against the screen. (Halogen can burn a spot if too close for too long like 15 seconds). If so, you probably have an inverter, backlight tube or coil/driver board problem. Some of these units have a bad ground on the tube driver coil board which can be shimmed and/or tightened. Sometimes a simple car light tester (continuity tester with a 12v bulb) from casing/mount ground to any of the negative (upper usually) side of the backlight driver coils will light the screen and reveal if and which tube is non functional. I leave one dome light running in such ground position one of my TVs at all times for regulation and night dimming.
2/28/2011 2:57:48 AM • Sharp LC-26SH10U... • Answered on Feb 28, 2011
I am trying to connect
I have this same model TV & am using it as a second computer monitor. I have mine running through an HDMI connection on input 4. I will mention it runs at 1280x720 recommended. I'm not sure if it's the display or just my video card, but mine can handle UP TO 1920x1080. Something to note, however, is that the TV has a natural refresh rate of 60 Hz. Check your video settings that they can handle that (or at least an even integer thereof). My card (ATI HD 5750) is running it at 30 Hz with some minor issues.
Final point: if you want the sound to pump out of your TV as well, remember to change the default sound device in your volume control panel.
12/29/2010 11:35:18 PM • Sharp LC-26SH10U... • Answered on Dec 29, 2010
Sharp digital tv cannot receive digital signal
This television would benefit from an hdtv indoor outdoor amplified antenna not obstructed by trees, aluminum, bricks, and etc. Make sure the signal type is air and not cable and complete a channel scan during primetime tv hours after connecting to this antenna. Buy a large one that you can mount to the wall usually in a large flat box on the shelf in the store. Philips has one sold at Walmart.
6/7/2010 5:45:58 PM • Sharp LC-26SH10U... • Answered on Jun 07, 2010
TV screen is blank but I still get sound
its probably the motheboard. i got one for sale cause i broke the screen. or you can sell me yours so i can fix mine. if your interested email me at [email protected]
10/25/2009 12:43:39 AM • Sharp LC-26SH10U... • Answered on Oct 25, 2009
My tv screen just went blank i still get sound but
its the motherboard. i got the same tv with cracked screen. i can sell you the motherboard for cheap or i will buy your lcd to fix mines. if interested email me at [email protected]
10/25/2009 12:41:56 AM • Sharp LC-26SH10U... • Answered on Oct 25, 2009
2answers
Power light on but no audio no video
There must have been an internal problem. Some ic's have gone bad. Go for a check to determine wat is to be changed.
It is a minor thing.
Rate this.
10/25/2009 12:39:08 AM • Sharp LC-26SH10U... • Answered on Oct 25, 2009
2answers
No picture, has sound
i have the same issue and after removing the back and doing a voltage test on cp506 and found the 24vdc that was suppose to be there lead me to the back light inverter. a very common problem for these tv's and if you can take a voltage test of vdc then you can confirm it! one problem the manufacture does not sell it seperate from the lcd panel so it is very expencive and to find them use they are hard to find because of them being a common problem! good luck and if you need help taking the voltage test let me know!
10/24/2009 3:03:21 PM • Sharp LC-26SH10U... • Answered on Oct 24, 2009
Sharp lc-26sh10u intermitent problem
its a motherboard problem. i got one for sale or you can sell me the tv cause mine has a broken screen
10/24/2009 6:28:01 AM • Sharp LC-26SH10U... • Answered on Oct 24, 2009
No power; no "red light" indicating standby
you can sell it to me or i can sell you mine so you can get it fixed. its the motherboard. i got one but with a broken screen.
10/24/2009 6:24:33 AM • Sharp LC-26SH10U... • Answered on Oct 24, 2009
5answers
Hi need a back light inverter for a sharp
Hi
Thanks for using FixYa. There are no fuses on the inverter board. If you are replacing the board this will help you--
Procedure for removing the Inverter board--
1. Remove the stand cover fixing screw (1 pc.).
2. Remove the stand fixing screws (4 pcs.).
3. Remove the carrying handle fixing screws (4 pcs).
4. Remove the terminal cover.
5. Remove the cabinet B fixing screws (10 pcs.).
6. Remove the cabinet B after opening from the direction of an arrow.
7. Detach the connector from each PWB.
8. Remove the 2 lock screws from the main PWB and undo the hooks a. Detach the main PWB, together with its
terminals, from the chassis frame.
9. Remove the 4 lock screws from the sub PWB and undo the hooks b, c, d and e. Detach the sub PWB together
with its terminals, from the chassis frame.
10. Remove the 3 lock screws from the operation PWB, and detach the operation PWB.
11. Remove the 3 lock screws from the inverter PWB and take out the inverter PWB.
Precautions at the time of the side-B(back) service of main, sub and Inverter unit—
1. Remove only SC1201 of the FPC for connection between Main unit (SC1201) and LCD panel (CN1), and connect the extended cable (QCNW-C458WJQZ) for service.
2. Remove the PWB unit fixing screws (main unit: 2 pcs., sub unit: 4 pcs., inverter unit: 3 pcs., operation unit: 3 pcs., R/C, LED unit: 2 pcs.)
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
9/25/2009 9:56:05 PM • Sharp LC-26SH10U... • Answered on Sep 25, 2009
My SHARP LC-26SH10U PROBLEM. POWERS RED THEN
HI, you will need to replace the Digital PCB in this unit. the chip set has become unstable. there is some major circuit damage as well. AKA(PWB UNIT)
Sharp Part Number: A3Y004GDH0 $262.95
6/21/2009 1:26:59 AM • Sharp LC-26SH10U... • Answered on Jun 21, 2009
Sharp LC-26SH10U 26 in. LCD Television Logo
24 questions posted
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
LC Sharp
  • LC Sharp
Most Popular Question
sharp digital tv cannot receive digital
  • Televison & Video
