20 Most Recent Akai LCT3285TA 32 in. LCD Television Questions & Answers
2answers
I bought a 2nd hand Akai KC02-A2 32
If you wish to get some details; visit the site linked here. Pull up older posts. sounds like the main board fault. http://electronicshelponline.blogspot.com/
12/28/2017 4:14:38 PM • Akai LCT3285TA... • Answered on Dec 28, 2017
AKAI LCT3285TA 32 inch LCD not compatible with Wni 7 video driver
try to right click on the driver and search for Program Compatibility Troubleshooter or the properties where you can run the program in compatibility mode in other os version
6/2/2017 1:10:28 AM • Akai LCT3285TA... • Answered on Jun 02, 2017
AKAI lct3285ta will turn on, show the akai logo and then turn off
Update the firmware. It is corrupted. Do a hard reset to this set, and then check. Sometimes it might help you. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
5/21/2017 11:44:59 AM • Akai LCT3285TA... • Answered on May 21, 2017
I have an Akai LCT3285TA television with scrambled colors.
The TCON board or the LCD panel is Faulty. Can confirm by replacing the TCON board . If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
6/10/2016 5:43:44 PM • Akai LCT3285TA... • Answered on Jun 10, 2016
3answers
Broken Screen on Plasma TV
Broken Screen on Plasma TV A broken TV screen can not be fixed. A replacement sceen can cost as much as a new tv since the new set prices keep falling. You can sell the unit for parts. (ebay?)
You can get a screen protector from;
http://www.tv-armor.com/
or fashion your own.
1/25/2015 7:43:24 PM • Akai LCT3285TA... • Answered on Jan 25, 2015
Zoom box stays on screen how can i turn it off
On the remote press the "exit" button. If that don't work try unplugging the TV then plug back on.
1/18/2015 4:15:34 PM • Akai LCT3285TA... • Answered on Jan 18, 2015
Akai ct-2202 tv turns on
sir . i need akai ct2202 remote control model no. i lost my remote in transit and without it i'm not able to use the tv. my mail id : [email protected] pls help. thanks & regard's. V.SRIKUMAR
1/27/2014 12:00:22 PM • Akai LCT3285TA... • Answered on Jan 27, 2014
0answers
Volumne on Akai LCT3285TA
Often a signal might experience a super-quick "drop" in signal strength, and the display is automatically adjusting the now weaker audio signal to "mono" (temporary, as for best quality). But the dropout is usually so brief you will then see the "stronger" signal restored [full strength], and now the audio is "stereo".
It's like a "bump" or "disturbance" that occasionally affects the cable/satellite/OTA (antennae) signal being fed into the TV, and your display's attempts to compensate for the weaker signal [going to mono, then back to stereo once back to full strength].
Connecting it to your cable directly (bypassing the box) or an antenna would give you a true over-the-air signal, which would be proper MTS and would not give you any more pop ups.
3/10/2013 3:29:52 AM • Akai LCT3285TA... • Answered on Mar 10, 2013
Picture is frozen
There is a button on the lower part of the remote that is a "freeze" button, it will freeze the picture, or capture a still shot. Try pressing this button to "unfreeze" your picture.
3/6/2013 6:36:58 PM • Akai LCT3285TA... • Answered on Mar 06, 2013
No signal
maybe your wire came lose in the back of your TV, look in back to see all connections.
12/30/2012 7:19:07 PM • Akai LCT3285TA... • Answered on Dec 30, 2012
No picture
Try the audio and video inputs on the set to see if have picture there with a DVD etcAlso possible if using a box or receiver in line they can cause this==I ask as I do not know what you have hooked up.If a box is used and rear inputs are ok unplug set and box for several minutes and plug back to see if a reboot helps.
12/21/2012 10:53:35 PM • Akai LCT3285TA... • Answered on Dec 21, 2012
2answers
How do i attach a Wall Mount to the TV?
Hi, Ok, great.Look at the back panel and you can see four holes spaced 4" between the top and bottom, and 16" from side to side. these are for universal mount. http://www.bestbuyplasma.com/Plasma/tvmounts_land.asp I think this clears your problem regards sreejith "Please use caution if wall mounting this product. Follow all directions from the manufacturer of the wall mount and be sure to securely fasten the product to the mount. While the TV can be wall mounted, improper wall installation may void the warranty."
11/25/2012 1:41:21 AM • Akai LCT3285TA... • Answered on Nov 25, 2012
Akai LCD tv model LCT3285TA will not respond to remote. Green and red lights at sensor are out
Hello,The most common cause of this type of power issue is a failure of the filter capacitors on the power supply board. Below is a picture of the board with the faulty capacitors circled, there are 2 more under one of the big black heat sinks. The board can be repaired by replacing the bad capacitors. Below the picture is a link to a kit of the correct parts for the board repair if you want to do the job yourself.10_12_2012_2_44_20_pm.jpghttp://www.ccl-la.com/catalog/product_info.php?products_id=240I hope this helps you out.
10/12/2012 2:45:15 PM • Akai LCT3285TA... • Answered on Oct 12, 2012
Tv powers on for about a second and then shuts off
The set will need to be serviced, it has a internal problem !
9/23/2012 1:23:32 AM • Akai LCT3285TA... • Answered on Sep 23, 2012
WHY WONT IT STAY ON?
If it goes on for a very short time (a secong or so) it could be the power suply unit.
9/20/2012 4:53:45 PM • Akai LCT3285TA... • Answered on Sep 20, 2012
The red light on my t.v. is flashing but my t.v. wont come on
I would try unplugging everything, then plug back in. Try new batteries in remote if there is one. This sounds like TV is not getting signal to turn on, so I would look carefully at remote power and 'eye' and power button connections. Good luck!
8/13/2012 8:42:32 PM • Akai LCT3285TA... • Answered on Aug 13, 2012
Akai LCT3285TA 32 in. LCD Television Logo
172 questions posted
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Akai Televison & Video
Most Popular Question
akai lcd tv model lct3285ta will not
  • Televison & Video
